Other options besides Super and Mini rams?
Old Oct 1, 2001 | 07:05 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Other options besides Super and Mini rams?
My new ZZ4 short block is gonna be limited by the stock intake quite a bit. I've heard of the super and mini rams but was wondering if there is anything else. How much would porting the stock base, runners, and plenum myself limit the hp? How much would they limit stock?
If anyone has one for sale email me :cheers: I want something for my winter project :jester Thanks!
Old Oct 1, 2001 | 07:07 PM
Vic'89's Avatar
Vic'89
Default Re: Other options besides Super and Mini rams? (vettes rule)
You can also buy the Large tube runners and aftermarket base. But these are still the TPI style intakes.
I have also seen carb intakes that have the holes for the fuel injectors. I think Holley and Accel make these.
Vic
Old Oct 1, 2001 | 10:44 PM
HWoods's Avatar
HWoods
Default Re: Other options besides Super and Mini rams? (Vic'89)
Lingenfelter and others are making fuel injectioon systems using a carb type intake with the injectors mounted in the runners, with a throttle body to flow the air. These are probably the best of both worlds with the effenciency of electronic fuel injection with performance equal to high performance carb/intake systems. Check Lingenfelters web site, and others. Do a web search for electronic fuel injection. These systems will allow better performance than a tpi or a mini ram type set up IMO
http://www.diy-efi.org/
http://home.swbell.net/nitro57/EFI.HTM (list of fuel injection sites)
http://www.blowerdriveservice.com/fuelinjection.htm
http://www.kinsler.com/m_efi.htm http://www.momarefi.com/images/momar017-3.jpg (weber throttle body electronic fuel injection, one of my favorites)
Just to get you started
[Modified by HWoods, 8:51 PM 10/1/2001]
[Modified by HWoods, 8:53 PM 10/1/2001]
Old Oct 2, 2001 | 07:53 PM
your drinking buddy
Cruise-In V Veteran
Default Re: Other options besides Super and Mini rams? (HWoods)
Thanks HWoods, anyone else?
Old Oct 2, 2001 | 08:32 PM
8388's Avatar
8388
St. Jude Donor '14
what are you trying to acheive, whats the cam spec. whats the comp. is the car a stick or auto, whats the gear ratio all of these things need to be considered in order to make the right choice.
Old Oct 4, 2001 | 12:14 AM
your drinking buddy
Cruise-In V Veteran
Default Re: Other options besides Super and Mini rams? (8388)
The car is an auto with the stock 2.59 gears but I want to move to 3.45 Dana 44 or so soon. The compression ratio is around 10.5-11:1 (i think), and the cam im not sure of except that its bigger than stock(trying to find specs). This is my daily driver so it has to be streetable but I want lots of low end and good power on top too, hopefully low 12's, high 11's in 1/4.
Old Oct 4, 2001 | 12:32 AM
8388's Avatar
8388
St. Jude Donor '14
The higher numerically the gear ratio, the more upper rpm your gonna want, think of the mini ram as an LT-1 or 4 it sacrifices alittle torque at lower rpm for higher rpm h.p. for a daily driver more torque is the way to go, I've had very good luck with the cast aluminum runners and factory intake having them extrude honed and making big block torque numbers, see if you can find an old TPIS hints book it does a vey good job of explaining how the different lenght runners perform and has examples on the dyno.
Old Oct 4, 2001 | 01:39 AM
Andy1983's Avatar
Andy1983
OK... this is WAY off topic, but the first time I saw a post by 8388. YOUR GARAGE... OH MY GOSH!
I went to your webpage and looked at your pictures.
Don't tell me you have that many vettes.
Freakin awesome.
I live in Plano, and would love to just come over to your house... or, your garage... and stare at the best garage ever.
:D
[Modified by Andy1983, 11:48 PM 10/3/2001]
Old Oct 4, 2001 | 01:50 AM
88WHITE VETTE's Avatar
88WHITE VETTE
I have Super Ram for sale if you decide to go that way.
It's all there, with 24# injectors, 58mmTB, fuel rail, fuel pressure regulator, planum, base and runners (also brand new set of gaskets). I was going to do it and purchased it, but than changed my mind and went with carburetor.
Ziggy
To Other options besides Super and Mini rams?
