fuel injectors
Old Jan 11, 2007 | 07:02 PM
CrippleDave's Avatar
CrippleDave
Default fuel injectors
hi, i just had my 89 corvette engine rebuilt and am about to put it back in. i want to replace the fuel injectors since they have 156,000 on them. my question is what fuel rate should i go with. the car is stock but i am planning to do a few mods in the future. what is the stock flow rate should i go with stock or higher? future plans for mods would include exaust, intake, and possibly a chip. Are accel injectors any better than stock? thank you for your time.
Old Jan 11, 2007 | 07:12 PM
geogolf's Avatar
geogolf
Default inj.
if you were going to put a high flow base on it now, i would go with 24#ford injs. that is what i am doing if no base i not sure about 24# i think stock is 22 not may cf members are accell users bosh makes a pink top 22 that is very good i am sure someone else will speak up or do a search for injs.
Old Jan 11, 2007 | 08:33 PM
biteme86's Avatar
biteme86
......I say get 24s.
Old Jan 11, 2007 | 08:35 PM
RRT vette's Avatar
RRT vette
In a stock 89, you have 22# Multecs. Yes, replace them with 22# of a different brand. Sam Lam will clue you in. Though if those are the stock injectors....looks like you got very good use out of them.
Old Jan 11, 2007 | 11:43 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Please do not use Accels!
Too many issues!
Ford SVO's are good
Old Jan 11, 2007 | 11:56 PM
CrippleDave
where could i get a good deal on fords? people said either 22 or 24, if i got 24's would there be a possibility of the car running too rich?
Old Jan 11, 2007 | 11:57 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Not good advice for the planned mods.
The 22's can be programmed for a longer pulse. The 24's will be problematic. Just ask RRT vette.
I bought a set (22's) off of ebay from five0motorsports for around $200 and Alvin did the tune. What a difference!
Old Jan 12, 2007 | 01:02 AM
VenkmanP's Avatar
VenkmanP
For just bolts-ons stick with stock size.
Accel are widely reported to suck.
Old Jan 12, 2007 | 05:14 PM
CrippleDave
where can i get a good deal on ford 22's? i need them soon because im dropping the engine in sunday.
Old Jan 12, 2007 | 06:05 PM
Kool88vette's Avatar
Kool88vette
Some C4 owners are running these with good results. http://store.summitracing.com/partde...5&autoview=sku I would suggest an AFPR also. I'm running 24lb injectors in my L98. I did the AFPR and a chip. Mine are accels. I guess I was lucky, No problems. At the time I didn't know that Ford injectors could be run in a L98. I would suggest the Fords. Some members have had problems with fiveomotorsports. They sell rebuilts and used injectors. For a few dollars more you can buy new Fords.
Old Jan 12, 2007 | 06:31 PM
CrippleDave
what is afpr?
Old Jan 12, 2007 | 06:46 PM
biteme86's Avatar
biteme86
what is afpr?
Adjustable Fuel Pressure Regulator
Old Jan 12, 2007 | 07:37 PM
gator79's Avatar
gator79
not trying to hijack this thread but I have a set of pink ford injectors out of a 2003 mustang GT that I got for free. anyone knowthe flow rate of theese, I have a '93 and my injectors are very noisy at times. the swap would not cost me a dime free mods
Old Jan 12, 2007 | 07:47 PM
Warp8's Avatar
Warp8
How's that working for ya?
Old Jan 12, 2007 | 07:54 PM
biteme86's Avatar
biteme86
You mean the Accels? Im sending RRT the $$ and I will post back once I get them in. If they do suck, Ill make sure to comment. BUT, if they are good...... If they do make it run rich or dont work out, I will resale them on here.....
Old Jan 13, 2007 | 09:53 PM
CrippleDave
would these be good from factory five, i think there ford style bosch... heck out the latest technology in fuel injectors for your L98 Corvette.
Click this link to read about the new
Bosch XF2E-22.5
injector set.
Complete as shown with 8 XF2E-22.5 and adapters.
$359.95 Complete set
are those 22.5's?
Old Jan 13, 2007 | 11:04 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Go to fiveomotorsports & put the must@ng info in, then your will know what injectors are stock and if you can use them.
To fuel injectors
Old Jan 13, 2007 | 11:28 PM
RRT vette's Avatar
RRT vette
Bosch XF2E-22.5
injector set.
are those 22.5's?
That sounds too high for 22lb injectors. I would either check fiveomotorsports or the FMS injectors. It would save you alot and be good injectors. Or you can send yours to cruiznperformance.com.
Old Jan 13, 2007 | 11:45 PM
gator79's Avatar
gator79
went there
http://www.fiveomotorsport.com/Injec...RD.asp#foted5b
still did see the flow rate
Old Jan 14, 2007 | 04:26 AM
CrippleDave
i am having trouble finding fords that are 22's im only seeing 24's and 19's. can somone send me a link to where i can find ford 22's at a good deal please?
