ZF6 fluid change
Old Jan 11, 2007 | 08:53 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Default ZF6 fluid change
Just a few observations on changing the fluid in a ZF6
1.The depth of the indentation where the 17mm hex fits in is very shallow Make sure this is cleaned out first. I used a small flathead
Ive seen posts here about stripping out the plug, I suspect that may be why
2.I used a length of hose about 3 feet long to refill
I ran it down between the engine and firewall and put a funnel on the end in the engine bay and just stuck the other end in the hole
I used garden hose The smaller diameter hose works better and I flushed it out with oil first
Clear tubing would also work
I have a pump but what a PITA
I followed the advice Ive gotten here such as making sure the fill plug would come off before taking out the drain and having the car level etc.
Later fellow Vette junkies
Old Jan 11, 2007 | 09:19 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I have a question. Do you need to put anti-seize on the plug when you reinstall it?
Thanks, Randy
Old Jan 11, 2007 | 10:27 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
NO.
To ZF6 fluid change
