On the intake manifold
http://i134.photobucket.com/albums/q...etteengine.jpg
Thanks! Looking forward to spring!
The other 4 bolts on each side are controlling the water passages. The water tends to have more resistance to wicking, or creep.
The answer seems to be adding silicone to the threads. But once that's done, you can't retighten them, for fear of fracturing the silicone sealing properties.
You can't keep removing and reinstalling those bolts with silicone on them because eventually you will push bits of cured silicone through the holes,and they lay in the lifter valley and eventually find their way to the pan, and into the oil pump pick-up screen.
Sometimes, i have to put copper (read soft) washers on the bolts and keep checking the torque on them as time progresses.
With each heating and cooling cycle, the aluminum, cast iron, and steel work together on the gasket pinch to flatten out the gasket every day that the engine runs, and shuts off and is allowed to cool.
In that the manifold and heads are aluminum, the block is cast iron, and the bolts are steel, the washers copper, the four metals tend to expand at different rates, and installing lock washers or silicone, or loc-tight only tends to aggravate the problem.
You can change to an external wrenching bolt (hex head) on those bolts,to make it easier to tighten,
BUT....... remember the middle 2 bolts on each side are shorter than the other 4 bolts because under the R/H forward center bolt is the pushrod, and under the L/H rearward center bolt is the other pushrod.
Lengthening those bolts might allow you to rub the pushrods on the bolts or bend them enough to make them crack and break, and send tiny pieces of metal through the oil to the oil pan where it may or may not be caught in the filter, depending on where the bypass valve is when the oil is the thickest.
So the best thing is to remove the bolts, squirt black, non amonia smelling silicone on the threads, and reinsert them.
Why non amonia smelling silicone? Because the types that smell like amonia attack aluminum.
Remember preparation goes a long way when doing things like this.
This is my vote.
