IAC Replacement
Old Oct 1, 2001 | 09:58 PM
tsquare's Avatar
tsquare
Default IAC Replacement
Can a replacement be bought from an autoparts store,if so how much do they run
Old Oct 1, 2001 | 10:01 PM
tan85vet's Avatar
tan85vet
Default Re: IAC Replacement (tsquare)
Yes it can, and they usually go from $40 - $50. Mine was about $45 if i can remember. Dont forget to clean the bore in the throttle body before you put the new IAC in.
Old Oct 1, 2001 | 10:32 PM
tsquare's Avatar
tsquare
Default Re: IAC Replacement (tan85vet)
Do you still have to set the idle after installing it?
Old Oct 2, 2001 | 03:25 AM
corvette1990's Avatar
corvette1990
There is a specific procedure in the manual and in the tech tips section about setting the IAC pintle length when hooked up to the cable and engine on, but not started. Either find the tip or a manual, is my best advice.
To IAC Replacement
