recently was forced to replace door on my 92 roadster (still in the process). I got the door from Karshop, it's from a 93. There is a slight difference, on the door jamb, upper rear, MY door had a little chrome guide which bolts in. The 93 door does not have that piece or the holes to mount it with. Examining the inside of the door, I see where the metal superstructure has a place for holes to be drilled, but no holes.
Here's my question. Is the door I purchased a coupe door? Or is it a change for 93. I have a roadster and it has the guide at the top rear of the door, and the female for the guide is mounted to the upper rear of the frame on the door opening. So again, is this guide an extra part of roadsters, or is a year change?
