High Oil Pressure?
Old Jan 13, 2007 | 05:47 PM
CRV3TT3's Avatar
CRV3TT3
Default High Oil Pressure?
hey guys,
just browsing the forum ive noticed people saying that their cars oil pressure drops to around 12-15psi at idle when warm and mine NEVER drops below 47psi ever and goes as high as high 60's under WOT! is this somthing that should be addressed or nothing to worry about?
thanks in advance guys!!
Old Jan 13, 2007 | 06:26 PM
Slalom4me's Avatar
Slalom4me
The following assumes that the oil & filter are in good shape,
that there isn't an accumulation of sludge (not common) and
that the gauge/sender are reporting accurately.
Do you know whether the oil pump has been changed?
High 60's psi at redline seems to indicate a pump with an aftermarket
spring for the bypass valve - these typically result in +/- 70 psi readings.
Views differ on maximum pressures, I follow the '10 psi per 1,000 rpm'
crowd. But consistently high 60's are not a showstopper - I would
not disassemble to change this were it my car.
About the high idle pressure - someone familiar with high volume
pumps (volume is a different pump characteristic than pressure)
might confirm that idle pressure goes up when a HV pump is used.
What brand & weight of oil is used. What filter?
Old Jan 13, 2007 | 06:28 PM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
your not the only one, my oil pressure is pretty high as well, nothing wrong with that in theory as long as its not too high, just lubing the motor well
Old Jan 13, 2007 | 06:34 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Better high than low. Mine is around 45-50 at 1700 rpm on the slab.
CRV3TT3's Avatar
CRV3TT3
im using full synthetic mobil 5/30...i dont have any idea what pump is in the car...if its a high volume it was there when i got it! lol
edit: the filter is just a fram with the easy grip on it? idk
Old Jan 13, 2007 | 06:41 PM
Slalom4me's Avatar
Slalom4me
Well, the pump is powered by the distributor, which is driven
by the back end of the cam, that is driven by the front of the
cam, which is driven by the timing chain. Reducing the pumping
pressure brings a buffet of benefits.
As for higher volume, unnecessary oil is bypassed within the pump
back to the inlet. Pumping action heats the oil, bypassed oil just
gains further heat as it recirculates.
Aim for the appropriate pressure/volume for your application.
Old Jan 13, 2007 | 06:50 PM
CRV3TT3's Avatar
CRV3TT3
the oil temp never goes above what the coolant temp is? idk
i guess its fine!
Old Jan 13, 2007 | 07:14 PM
Slalom4me's Avatar
Slalom4me
I guess it's fine!
Your '87 likely has the effective OEM oil-to-water oil cooler. This
looks like an 1-1/2 - 2" adapter fitted between the filter and the block,
there is a metal tube that runs under the forward section of the oil pan
(for coolant).
When the engine is under load for a time (track events), oil temp will
come up. As long as it is under 240-250, life is good. With synthetic,
track people run sessions and report seeing 280-300 and more
- personally, I'd find a solution if this happened with my car. Not
an issue for you.
The 5W-30 won't cause high idle psi (20W-50 might elevate psi)
Is FRAM respected now? ACDelco have been well-regarded in the
past.
Old Jan 13, 2007 | 09:35 PM
rodj's Avatar
rodj
"mine NEVER drops below 47psi ever and goes as high as high 60's under WOT!"
If you are basing that on the OE dash gauge ,maybe check with a aftermarket mechanical gauge to confirm actual pressures.
Mine showed similar readings ,showed normal with mech gauge.
Sender unit at rear of block was playing up.
Old age
Old Jan 14, 2007 | 04:24 PM
CRV3TT3's Avatar
CRV3TT3
the car does have the factory oil cooler...and ill check with a different gauge...
Old Jan 14, 2007 | 07:30 PM
Louis Bartay's Avatar
Louis Bartay
(for coolant).
an issue for you.
past.
Fram filters were not given a good rating on a oil filter test I read. The AC Delco and Mobil 1 and K&N were rated very good.http://minimopar.knizefamily.net/index.html read all the information about the filters they have tested.
Old Jan 15, 2007 | 11:40 PM
bonbliss's Avatar
bonbliss
Default 80 psi
hi evryone thanks to all in advance my 88 4+3 has a psi of 80 is this fine or to high just not to sure whats normal psi?
hailz!!!!corvette
Old Jan 16, 2007 | 01:00 AM
Slalom4me's Avatar
Slalom4me
Originally Posted by bonbliss
My 88 4+3 has a psi of 80. Is this fine or too high?
80 psi on your completely stock TPI L98 daily driven street car is
approximately 30 PSI higher than it needs to be.
Old Jan 16, 2007 | 07:09 AM
rodj's Avatar
rodj
hailz!!!!corvette
Read my post above about confirming actual oil pressure not indicated pressure
At that # ,more than likely your sender unit is cactus.
Old Jan 16, 2007 | 09:42 AM
Tom Piper's Avatar
Tom Piper
Some quick ways to check if your electric oil pressure gauge is accurate:
1) With the key on and the engine not running, it should read zero.
2) Disconnect the electrical connector at the oil pressure sending unit, the gauge should go full-scale.
3) Short the sending unit connector to ground, it should be at the bottom of the scale.
4) Check with a known good mechanical gauge -- do you get the same reading?
Tom Piper
Old Jan 16, 2007 | 02:49 PM
Louis Bartay
Tom Piper
Thanks Tom, good information .
Louis
To High Oil Pressure?
