Jumpy Timing Line/Thoughts? Kinda Long
Old Jan 13, 2007 | 09:26 PM
Dads90's Avatar
Dads90
Default Jumpy Timing Line/Thoughts? Kinda Long
I've been experimenting with the timing on my car. If any has been following my threads I finally got the fuel injectors and intake manifold gasket replaced, (along with other things). I am presently trying to solve a late ignition timing concern. My vaccum gauge is showing 15 inches. I tried to run the timing up to 10 BDC. But when I connect the EST wire it adjusts it to almost straight up under the water pump area. Also the line is jumping erraticly back and forth. Is that correct ? At 6 BDC the line jumps between 10 and sometimes 12. I' am not sure how the ECM is supposed to adjust. I have done all the vaccum leak checks possible, (except smoke), carb cleaner, WD 40, water, propane, nothing seems to effects the engine idle speed. I turned the dist. cap with the vac. gauge on the brake boost line to watch its affect as I turned it. To get the reading to normal (17 in) I could'nt advance it enough. Set it at 7 BDC. Runs good, slight lag in the gas mileage dept, idles good, except it has a ever so noticeable miss. The exhaust kind of sputters and the tach will show 900 rpm, then 700 rpm, 1000 rpm. Doesn't flucuate visibly, just notices its there. Ive included pictures, (Note vacuum lines look good) This is a lot info, Its been a long process figuring this one out. Help !!!
Old Jan 13, 2007 | 09:48 PM
Photomania's Avatar
Photomania
I'll be interested in finding out your outcome. I also have a 1990 six-speed coupe and the engine just recently started idling slightly rough. Sometimes it idles smoothly. But I usually notice a rough idle when I'm sitting at a traffic light. It has 102,000 miles. It was running fine until I installed an inlet fairing that was supposed to increase the horsepower. I removed the gadget and sent it back to the distributor, but the idle is still slightly rough at times. I haven't done any of the testing that you described. Good luck. I hope you solve the problem. Maybe I can learn something from you.
Old Jan 13, 2007 | 09:52 PM
kopbet89c4's Avatar
kopbet89c4
You are supposed to set base timing with the EST wire disconnected. I just noticed you also have all those pesky vacuum lines from the EVAP and EGR. You vacuum leak might be there somewhere around those vacuum lines, causing an unstable idle. Plug the 2 ports on your TB (one on the pass side, below the PCV port and small one under the TB) and see if that temporarily smooths out the idle.
Old Jan 13, 2007 | 09:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yes the timing should jump up when you connect the EST as the ECM is then in control of ignition timing.
Since you have hunting idle if plugging the various vac ports doesn't locate a vac leak:
-clean the TB bore & plates w/ TB cleaner
-remove the IAC and clean the pintel & bore under the TB
-reset base idle
To search for that miss clip a timing light in turn onto each wire to see if missed flashes on one or more wires coincides with the engine miss.
Old Jan 13, 2007 | 10:20 PM
Dads90's Avatar
Dads90
-reset base idle
I've done all this. Actually replaced the IAC. Used Vader86 tech tip on resetting idle, IAC, TPS, etc. I won't give up. I do like the idea of putting the timing light on each plug. I did notice the light would flucuate every so many seconds connected to #1. This is what I need, good ideas, thanks so far.
Old Jan 14, 2007 | 10:06 AM
C409's Avatar
C409
Default vacuum
Just a thought : Have you verified the accuracy of your vacuum guage??
Old Jan 14, 2007 | 10:41 AM
wro87's Avatar
wro87
Just a thought that you might want to check out the harmonic balancer. It might be sliping (vulcanized joint failing) which would really throw the marks off. Had it happen on ours. Right after we put the new engine in. wro87
Old Jan 14, 2007 | 01:13 PM
Dads90's Avatar
Dads90
Default Heater/AC vacuum line
Actually no, the gauge I got is new, harbor freight , first time it was running bad the mechanic I took it to said it was pulling 6 inches, posible cracked manifold, (pulled it, looked fine, replaced gasket). Car has 40K and I got 15 inches first time I hooked it up. Did a lot of setting, still searching for a vacuum leak. The gauge was cheap, (I know,,,you get what u pay for) needed something quick, and the local autoparts sources didn't have anything. Does any one know how hard it is to access the vaccum line that is linked to the heater/AC ?
Old Jan 14, 2007 | 01:19 PM
Dads90's Avatar
Dads90
Wouldn't it waiver even if the EST wasn't connected? It is steady on the degree I set it. Until I reconnect the EST and then it goes wacky.
Old Jan 14, 2007 | 01:26 PM
wro87's Avatar
wro87
That is how mine started out. Really bugged us out on how it would move out after hooking up the EST. wro87
Old Jan 14, 2007 | 02:54 PM
Dads90's Avatar
Dads90
Are there any signs of this to check for ? Its hard to see from the top with the accessories in place. Will ramp it and check underneath. I noticed their is alot of crud build up setting on it. Had to poke a stick with a rag to clean it up.
To Jumpy Timing Line/Thoughts? Kinda Long
