Gear ratio codes for C4???
Old Oct 2, 2001 | 03:02 AM
vette&fun's Avatar
vette&fun
Default Gear ratio codes for C4???
There are codes such as GM1, GM3 etc..... What are they? How to know which is which? What is my car gear ratio if it has the code GM3?
Old Oct 2, 2001 | 04:31 AM
Torquem's Avatar
Torquem
Default Re: Gear ratio codes for C4??? (vette&fun)
i beleive gm3 is the warp core code. You are lucky. Should do 0-warp9 in a flash of light.
Old Oct 2, 2001 | 08:30 AM
fiddleplayer's Avatar
fiddleplayer
Default Re: Gear ratio codes for C4??? (Torquem)
Try here.
http://www.hashmarks.com/codes.htm
Looks like you have a 3.45
FP
Old Oct 2, 2001 | 01:31 PM
emoshn's Avatar
emoshn
Default Re: Gear ratio codes for C4??? (fiddleplayer)
so what ratio is a G92 performance axle?
Old Oct 2, 2001 | 02:03 PM
ZylaRace's Avatar
ZylaRace
GM3 = AXLE REAR, 3.45 RATIO
G92 = AXLE REAR RATIO, PERFORMANCE (versus Economy)
Sorry, no usefull info on the G92.
You should have another code that will get you specifics.
Old Oct 2, 2001 | 03:00 PM
fiddleplayer
Default Re: Gear ratio codes for C4??? (ZylaRace)
The G92 option is the performance axle for automatics only. 84-91 3.07 to 1, after 91 I don't know.
Here is a link to some corvette RPO information.
http://users.acs-isp.com/crowz/rpocodes.htm
[Modified by fiddleplayer, 3:27 PM 10/2/2001]
Old Oct 2, 2001 | 03:30 PM
dgoodhue's Avatar
dgoodhue
Some standards also had a rare G92. Anyways, G92 is GM's universal code for a performance axle ratio. C4, C5, F-bodies, G-Bodies, trucks all using this code for a optional performance axle ratio. It doesn't correlate to any particular ratio, unless you know what the option ratio were for that year.
Old Oct 2, 2001 | 03:50 PM
Scoob's Avatar
Scoob
GH0 AXLE REAR, 3.54 RATIO
GH2 AXLE REAR, 2.29 RATIO
GH3 AXLE REAR, 2.77 RATIO
GH4 AXLE REAR, 2.92 RATIO
GK9 AXLE REAR, 4.63 RATIO
GL3 AXLE REAR, 6.17 RATIO
GM1 AXLE REAR, 2.59 RATIO
GM3 AXLE REAR, 3.45 RATIO
GM8 AXLE REAR, 2.56 RATIO
GS4 AXLE REAR, 3.70 RATIO
GT4 AXLE REAR, 3.73 RATIO
GT5 AXLE REAR, 4.10 RATIO
GT7 AXLE REAR, 3.33 RATIO
GT8 AXLE REAR, 4.10 RATIO
GU1 AXLE REAR, 2.41 RATIO
GU2 AXLE REAR, 2.73 RATIO
GU4 AXLE REAR, 3.08 RATIO
GU5 AXLE REAR, 3.23 RATIO
GU6 AXLE REAR, 3.42 RATIO
GV2 AXLE REAR, 5.83 RATIO
GV4 AXLE REAR, 3.36 RATIO
GV8 AXLE REAR, 2.72 RATIO
GW4 AXLE REAR, 3.31 RATIO
GW6 AXLE REAR, 3.27 RATIO
GW9 AXLE REAR, 2.93 RATIO
To Gear ratio codes for C4???
