Do It Yourself AFPR
Old Jan 15, 2007 | 02:34 PM
Roger anderson's Avatar
Roger anderson
Default Do It Yourself AFPR
On the 3rd gen site there is a tech tip for a do it yourself adjustable fuel pressure regulator. Basically you remove the cap, weld a 1/4" nut on it and put a 1/4" bolt in the nut, install a ball bearing on the diaphram, and put it back together. Has anyone tried it?
Old Jan 15, 2007 | 02:37 PM
Ttime's Avatar
Ttime
Never heard it done, but it sounds interesting
Old Jan 15, 2007 | 08:50 PM
RRT vette's Avatar
RRT vette
Something like this?
https://www.corvetteforum.com/techti...=154&TopicID=2
Old Jan 15, 2007 | 09:30 PM
STL94LT1's Avatar
STL94LT1
TPIS sells a AFPR hat for the stock LT1 regulator. I've been running one for 4 years without a problem.
Old Jan 15, 2007 | 10:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
...install a ball bearing on the diaphram, ...
I heard of this mod but using a flat Al plate under the bolt, over the diaphram.
Old Jan 16, 2007 | 12:17 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Originally Posted by RRT vette
So basically by removing the vacuum this guy just set the pressure at WOT pressure, which is high. Interesting. Why do we need the regulation of the regulator on our engines. Why not just have the
injectos at whatever pressure you need all the time, instead of relying on the regulator to get it where you need it.
Old Jan 16, 2007 | 06:19 AM
Roger anderson
From what I can see in the advertisments in the magazines, it looks like all that comes with the kit is the cap, new bolts, and plenum gaskets. Seems like a lot of money for so little product.
Old Jan 16, 2007 | 06:47 AM
JoBy's Avatar
JoBy
That is what he did, and it is a BAD thing to do.
With this mod you raise fuel pressure at idle and low throttle. During WOT it is the same as before. The ECM will detect a rich condition and try to lean down the engine when you cruise. During WOT it will run lean - BAD.
The fuel pressure regulator is a REGULATOR to keep the differential pressure over the injector constant. With a constant differential pressure over the injector each mS of fuel spray will deliver the same amount of fuel. If the differential pressure varies then the ECM has no control over fuel metering.
The vaccum hose is there for a reson
To raise fuel pressure you should increase the preload of the spring in the regualtor. By welding a nut to the cap and have a bolt that move the spring retainer you can adjust the spring preload. Aftermarket AFPR are just that, a new cap with a nut and a bolt to move the spring retainer.
Old Jan 16, 2007 | 11:19 AM
steve40th's Avatar
steve40th
That explains it very well. Thanks
Old Jan 16, 2007 | 12:20 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
The idea behind the vaccum sourced regulator is to provide (close) to the same pressure differential across the injector regardless of manifold vaccum.
To Do It Yourself AFPR
