Center Console ?
Old Jan 15, 2007 | 08:05 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Center Console ?
My spring popped out if the button, can someone tell me how to put it back in?
Thanks!!
Old Jan 15, 2007 | 10:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If it's like my '88, remove the console lid inner cover plate and you'll see where the spring should go.
If it popped out it's likely broken, MAM has replacement springs for $6.99.
Old Jan 15, 2007 | 11:42 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default spring
if the button popped out, it's probably broken, not the spring.
take the lid off, and turn it upside down on a towel or soft cloth , and remove the screws. nothing will happen except the light bulb over your head will come on.
when I repaired mine, I improvised with a piece of plastic that I filed to the right dimensions.
there is a cavity under the button if the lid is upside down, and in that cavity is where I put the plastic.
If the spring is broken(sounds like it is not) you can replace that.
If the buton is broken and can't be fixed, buy a lid from someone whose lid upholstery is trashed, and use the guts.
Old Jan 16, 2007 | 12:06 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
What is MAM's web address
Old Jan 22, 2007 | 02:57 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Ok, I got a new spring. But how does the spring fit?
Old Jan 22, 2007 | 04:11 PM
65Z01's Avatar
65Z01
Remove the console lid and then its inner liner and you will see where the spring goes.
Old Jan 22, 2007 | 04:46 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I see where it goes, just not how it fits in place.
Old Jan 22, 2007 | 05:04 PM
65Z01's Avatar
65Z01
Can you post a pic of the underside of the colnsole lid and of the spring?
Old Jan 22, 2007 | 06:08 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Can someone post the pic for me?
Old Jan 23, 2007 | 01:51 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
ttt
Old Jan 24, 2007 | 01:59 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
If you look at my profile, you will see the pic of the spring and lid.
To Center Console ?
