Transmission Fluid
Old Jan 17, 2007 | 12:47 AM
buzltyr's Avatar
buzltyr
Default Transmission Fluid
Is anyone running Royal Purple in their MN6 C4 transmission. If so what Royal Purple product are you using. Do you notice a difference? Good or bad?
Old Jan 17, 2007 | 08:08 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you drag racing, auto-crossing or engaging in other activities that would stress the transmission and AFT fluid?
If not, the benefits of synthetic ATF might be hard to justify from a cost analysis perspective.
Old Jan 17, 2007 | 05:07 PM
pablocruise's Avatar
pablocruise
OD, looks like he is referring to the 6 speed. That would only be 2.2 qts I think.(???)
Old Jan 18, 2007 | 06:42 AM
94z07fx3's Avatar
94z07fx3
Aye 1995 + MN6 = ZF
So....I'd stick with the FAQ's pick of GM or BMW fluid.
Old Jan 18, 2007 | 07:56 AM
onedef92's Avatar
onedef92
:o Whoops. My bad. Reading is fundamental like a ****...
Old Jan 18, 2007 | 07:59 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
Default GL rating....
.....for the transmission has to be matched to which ever fluid you intend to use. Go to zfdoc.com and read the article on the fluid testing that Bill had done. In the article it defines what GL rating ZF requires for our transmissions. I don't remember the exact GL rating and much else from the article but the most important fact I took with me was that GL ratings are specific. If the trans needs GL5 then that's it, no other GL rating can be substituted. I think our trans needs GL3, but go look for the info before you pick a fluid to use....it's way important.
FWIW, I have a 90 ZR-1 and I alternate between using the GM stuff and the BMW stuff.....just depends if I'm near the BMW dealer or if I'm at the chevy parts counter....but I change it every year or before 15K miles at the absolute outside. I feel it's cheap insurance, it costs too much to rebuild one of these....it ain't like an M22, those are easy compared to a ZF6spd.
Tom
Sorry to be so long on this but just to show how important the fluid is in our registry we had a rash of failures of Z owners using a synthetic fluid other than the BMW or GM stuff....90% of the trouble was traced back to incorrect GL ratings.
To Transmission Fluid
