disconect drive shaft
Old Jan 17, 2007 | 01:01 AM
tonycorvettehd's Avatar
tonycorvettehd
Default disconect drive shaft
im picking up a 93 in naples florida and putting it on a dolly to bring back to baton rouge la. anyone can tell me how hard it is to disconect the drive shaft so i dont hurt it,its and automatic?/thanks
Old Jan 17, 2007 | 01:28 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I put mine on 4 jack stands and move the brake cable and remove the 4 nuts on the drive shaft.
Old Jan 17, 2007 | 01:29 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Its easy but cant you put the car in N?
Anyways each U joint has some small,I think 8 or 10 MM bolts holding the straps on,take some off and then U joint can come out.
Old Jan 17, 2007 | 01:40 AM
STL94LT1's Avatar
STL94LT1
I don't know about the A4's. But, my 94 M6 was a PITA to get the driveshaft off with driveline support beam in place.
Old Jan 17, 2007 | 03:34 AM
REDC4CORVETTE
You did not say weather it's a coupe or a vert?
I have a vert and what a PITA to get the drive shaft out.
Just put it in nuteral and turn the key back to off possesion.
You can also remove the nut on the shifter lever under the car at the trans.If you jack it up.
Old Jan 17, 2007 | 04:09 AM
VenkmanP's Avatar
VenkmanP
Either get a proper trailer or drive it.
Old Jan 17, 2007 | 10:04 AM
c4cruiser's Avatar
c4cruiser
Towing an auto tranny car with the rear wheels on the ground and the driveshaft in place is not a good idea The driveshaft will turn the tranny output shaft and that will build up heat inside the tranny and because the enginge is not running, there will be no way to cool the tranny.
I would either drive it back or rent a truck and trailer to haul it. You should be able to get a U-Haul trick and trailer in Naples. Or maybe fly to Naples??
Old Jan 17, 2007 | 11:16 AM
SJW's Avatar
SJW
I was just looking at what's required to remove the shaft on my '94 ragtop, because I need to replace the tailshaft seal. Looks to me as though I'll need to drop the x-brace, and the exhaust from the cats back. Then it may be difficult to sneak the shaft past the C-Beam (won't know for sure 'til I try it).
Be well,
SJW
Old Jan 17, 2007 | 11:39 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Don't even THINK about towing the car with the trans in nuetral! You WILL destroy the trans. If you must use a dolly put the rear wheels on the dolly
Old Jan 17, 2007 | 11:52 AM
Bad Karma's Avatar
Bad Karma
You can rent a trailer from U-Haul that you can drive the car up on and have all four wheels off the ground. This is what I would recommend.
Old Jan 17, 2007 | 01:09 PM
zr1fred's Avatar
zr1fred
You might want to use a car hauling service, that distance should run about $300-$500. Not so bad when you figure cost of doing it yourself.
Old Jan 17, 2007 | 03:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
zr1fred
if you do pull the shaft make sure and drain the trans fluid first. Otherwise once you get the front end up and the shaft out youll spill fluid everywhere.
Old Jan 17, 2007 | 05:02 PM
pablocruise's Avatar
pablocruise
I've seen this happen. Don't do it!
Old Jan 17, 2007 | 05:27 PM
caa5030's Avatar
caa5030
If you do this, once your get up to about 45-55mph the front of the vette will start to make your rig fishtail. Don't try pulling out of the fish tail it doesn't work, just gets worse. Either definately drop the drive shaft or get a full trailer.
Old Jan 19, 2007 | 09:46 AM
jsinga's Avatar
jsinga
The driveshaft has to be forces out between the body and C-beam. (I got my 87's out) The manual says to take the C-beam loose.
You also have to deal with the exhaust pipes. You may have to take something else off or loose.
Old Jan 24, 2007 | 09:15 PM
tonycorvettehd
i ended up renting a u haul traler,it wasnt that expensive,,,thanks all
Old Jan 25, 2007 | 12:27 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default trailer
PHEW! I think he listened to the forum.........what a smart person
To disconect drive shaft
