Fuel pressure?
Old Jan 17, 2007 | 10:37 PM
92lt1vet's Avatar
92lt1vet
Default Fuel pressure?
looking to see what the stock fuel pressure is on a 92 lt1 vette, also just added aeromotive reg and what should it be with just bolt on mods? and where i can get a guage from to check it any help is greatly appreciated thanks mike
Old Jan 17, 2007 | 10:50 PM
RRT vette's Avatar
RRT vette
Your fuel pressure should be in the low to mid 40's stock. Only a tuner can tell you what fuel pressure is right for your applications. You can get a fair fuel pressure guage at a autoparts store ($40).
What size injectors? (stock 22's)?
What are your bolt-on mods?
Old Jan 17, 2007 | 11:04 PM
92lt1vet's Avatar
92lt1vet
yes stock injectors thought they were 24s but mayb not, msd cap rotor plugs wires, hypertech crank and alt pulleys.aero fpr,373 dana 36,k&n filter and modded air box
Old Jan 17, 2007 | 11:24 PM
RRT vette's Avatar
RRT vette
85..24lb
86-93..22lb
94-96..24lb
I would say use your stock fuel pressure with the mods you listed. Running a scan on your ECM will show where your fuel pressure setting is best..looking at the BLM's.
To Fuel pressure?
