165 to 727
Old Oct 2, 2001 | 05:00 PM
snaketr's Avatar
snaketr
Default 165 to 727
Who has done this ecm conversion, just wondering how hard it was and what was involved.
Old Oct 2, 2001 | 06:54 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 165 to 727 (snaketr)
easier to go from the 165 to the 7730.. since both are in-car type.
going to the 727 is more involved
Old Oct 2, 2001 | 10:20 PM
snaketr's Avatar
snaketr
Default Re: 165 to 727 (-=Jeff=-)
Is the 7730 a mass air or is it speed density?
Old Oct 2, 2001 | 10:43 PM
Rich B.'s Avatar
Rich B.
Excellent write-up here...
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
730 is speed density (MAP)...
Old Oct 3, 2001 | 12:45 AM
jmr302's Avatar
jmr302
What's wrong with the 165? I'm ignorant of the differences.
Old Oct 3, 2001 | 09:34 AM
Aaron's 87's Avatar
Aaron's 87
Default Re: 165 to 727 (jmr302)
There's nothing wrong with it, it's just MAF. The 165 MAF system only reads up to 255 g/s, which maxes out quick on a hot motor. The MAF is also an intake restriction. You can still properly run a MAF car above 255 g/s, but it's sort of fudging. MAP has no intake restriction and no airflow reading limit because it measures engine vacuum.
Old Oct 3, 2001 | 10:38 AM
Rich B.'s Avatar
Rich B.
Default Re: 165 to 727 (Aaron's 87)
The 1227165 ECU also uses a 128kb EPROM; the 1227730/1227727 use a 256kb EPROM. More space means more room for variables.
The 730/727 is regarded as the "Tuners ECU". For the swap, the 730 is preferred over the 727, since it's easier to get into to swap EPROMs.
Doing a Search in the Archives here will turn up a pretty comprehensive discussion on the conversion.
BTW: Plan on a custom chip if you do this swap. You'll need to modify the later Corvette memcal/EPROM BIN from the 730/727 to suit your car.
Parts needed are the 730 ECU; the new memcal (unless you get a boneyard ECU with a V8 memcal); at least one more 32 pin ECU harness connector (try to get all 3 - they're better); the MAP sensor and mounting bracket and harness connector; a newer '91 knock sensor...
You need to repin your harness connectors; modify your ECU mounting bracket to accept the side-mount harness; disconnect/remove your MAF sensor & housing (use mackeyred96 Traffic Control Cone!); install MAP sensor, bracket, and harness...
There's some more, but that's all I can recall right now...
[Modified by Rich B., 9:48 AM 10/3/2001]
Old Oct 3, 2001 | 12:23 PM
ZylaRace's Avatar
ZylaRace
Default Re: 165 to 727 (Rich B.)
My info say's the 730 is an "F" body ECM (90-92). The 727 is the "Y" body version (90-91). Both are first generation speed density systems.
Old Oct 3, 2001 | 12:25 PM
ZylaRace's Avatar
ZylaRace
Default Re: 165 to 727 (ZylaRace)
727 is suppose to be the underhood version of the 730?????? (Not sure about above comment.)
What I have been told.
Old Oct 3, 2001 | 12:27 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yes 7730 and 7727 are the same with the exception that the 7727 is for under the hood and the 7730 is for under the dash..
Jeff
Old Oct 3, 2001 | 01:18 PM
Rich B.'s Avatar
Rich B.
I have a 730 on my desk; never looked close at a 727, but I've been told it is harder to get at the memcal because the 727 case is sealed (waterproofed; board glued to case; etc). I've seen one from a few yards, and the case seemed to be a cast/finned unit...
To 165 to 727
