Surge tank bubbling
Old Jan 18, 2007 | 08:27 PM
LannyL81's Avatar
LannyL81
Default Surge tank bubbling
I noticed the other day that the high mounted surge tank began to bubble after I shut off the engine. Bubble as in boiling...lots of noise. Is this telling me to get a new cap for it, cause it is not holding pressure?
Old Jan 18, 2007 | 08:31 PM
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by LannyL81
I noticed the other day that the high mounted surge tank began to bubble after I shut off the engine. Bubble as in boiling...lots of noise. Is this telling me to get a new cap for it, cause I am not holding pressure?
is the coolant foamy on the top too? could be head gaskets
Old Jan 18, 2007 | 10:05 PM
Carolina C4 Racer's Avatar
Carolina C4 Racer
It could be the cap. I once replaced my cap only to realize that the inside neck of the surge tank had split.
Hope this helps.
Old Jan 18, 2007 | 10:47 PM
STL94LT1's Avatar
STL94LT1
What temp was the car running at this time?
Old Jan 18, 2007 | 11:23 PM
LannyL81's Avatar
LannyL81
Coolant in surge tank is not foamy, appears completely normal. Level once the coolant cools off is right near the top.
I just had the engine idling in the driveway last night; digital temp went to 225 and the main radiator fan came on, dropping temp to 205. I then shut it off.
The one thing I did notice was that the overflow bottle level never changed from the cold level. I had the heater going, trying to see if I could get more than just warm air out during all of this. But the overflow level bothers me.
Exhaust was also rather humid and I was dripping water at the muffler weld. The dripping stopped after all was hot, so I assume it was just condensation in the exhaust...but maybe not...maybe I do have a leaking head gasket or two.
Old Jan 18, 2007 | 11:53 PM
Ttime's Avatar
Ttime
Condesation (dripping) coming from the exhaust is normal. My Dad's Harley does it.
Don't worry about it.
Old Jan 19, 2007 | 07:20 AM
Mr6spd's Avatar
Mr6spd
[QUOTE=donhall;1558578702]
...."surge tank began to bubble after I shut off the engine. Bubble as in boiling...lots of noise."
.....Boiling is normal at shut-down as the cooling process has stopped.
"I am not holding pressure".....
......The cap is doing its' job, releasing excess pressure and expanded coolant into the overflow bottle.
What you want to be concerned about is the level of coolant in the surge tank when "cold". If the tank is not full when cold, then there is a break in the 'closed system', and coolant is not being siphoned back from the bottle to the tank as cooling takes place. Check all hose connections for any trace of moisture, making sure the connection in the over-flow bottle is secure and submerged. If the 'break' is small, moisture may not be evident due to immediate evaporation on a hot surface.
If coolant is not evident around the tank neck when the boiling occurs, then you can eliminate a break in the neck as a problem. Pressure would force coolant to be expelled through any fracture.
If the surge tank is not refilled during cooling (and the over-flow bottle is always full when cold), and there is no evidence of a break in the system, then one can suspect exhaust gases may be entering the cooling system through the head gasket. If operating temps are normal, then you probably don't have a head gasket problem.
That covers it all
To Surge tank bubbling
