Dyno sheets
Jan 19, 2007 | 05:21 PM
Dyno sheets
Hello
Im looking for dyno sheets of bone stock lt1 vette, lt4 vette and lt4 hotcam vettes. I hope you can be of assistance.
Jan 19, 2007 | 05:22 PM
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Jan 19, 2007 | 05:52 PM
Quote:
Originally Posted by
devilfish
Hello
With a six speed stock Lt1's run in the 273-280 range, LT4's in the 290-303 range. Dunno about hot cams.
Exactly what are you looking for???
Jan 19, 2007 | 05:53 PM
NoVa Events Coordinator
St. Jude Donor '14
Stock LT4 and LT4 hotcam dyno sheets can be found here:
http://www.grandsportregistry.com
Jan 20, 2007 | 05:16 AM
d48mclain
I would like to se where in the RPM range those cars makes the most torque and power.
Bluewasp
thanks alot !
Jan 20, 2007 | 08:56 AM
devilfish
OK......so exactly what are you looking to do with that knowledge??
Jan 21, 2007 | 07:38 AM
d48mclain
Learing more about tuning. Looking at dynosheets of stock vettes compare that to stock GM timing and fuelmaps. Compare it to other sources of material I have on the subject. Se the patterns, test for your self. Then perhaps learn somtehing..
Jan 21, 2007 | 12:53 PM
92 lt1 with 115k on it through a ZF.. Everything was stock except for a B&M shifter and the MSD ignition(6al box, blaster coil, and 8.5 wires) Neither of these will give you any power
trq peaked at 293 just under 4000 rpm
hp at 262 at just under 5000 rpm
Not knock your socks off impressive by any means, but decent for 115k on the clock
This was a Dynojet and these are SAE corrected
Jan 22, 2007 | 03:53 AM
