Need Help... Wires under dash
Old Jan 19, 2007 | 10:13 PM
Bubba91's Avatar
Bubba91
Default Need Help... Wires under dash
EDITED: Nevermind. It kept blowing door lock fuses, so I took it all out.
Old Jan 19, 2007 | 10:57 PM
quicktsi's Avatar
quicktsi
http://www.bulldogsecurity.com/
Look under vehicle wiring diagrams. If that is not enough specific information, try posting in audio.
Old Jan 20, 2007 | 12:54 AM
Hooked on Vettes's Avatar
Hooked on Vettes
I don't have a 91 manual but on a 90 and 93 they show two wires going to the switch mounted on the back of the door key cylinder.
Black/White is ground.
Light Green wire goes to the CCM.
When the key cylinder is turned in the direction to disarm the alarm, the Light Green wire is shorted to ground via the Black/White wire. This tells the CCM to turn off the alarm if it was set.
So your Bulldog alarm would splice into the Light Green wire. It would ground the Light Green wire to turn off the alarm. You should beable to splice into it at the kick panel.
Old Jan 20, 2007 | 12:58 AM
Bubba91's Avatar
Bubba91
I found two black/white wires at the kick panel. Can I use either?
Old Jan 20, 2007 | 01:06 AM
Hooked on Vettes
No you want to splice into the Light Green Wire.
The Black/white wire is just ground.
Old Jan 20, 2007 | 01:17 AM
Hooked on Vettes
The schematic shows the Left Hand power mirror has four wires going to it's motors. Yellow, White, White/Black (ground wire) Pink wires for heating element.
The Right Hand mirror does show a Light Green wire going to one of it's motors.
That Light Green wire that goes to the power mirror switch is for the Right Hand mirror control.
That is not the Light Green wire you want. You want the Light Green wire at the Key Cylinder.
It has to be in the bundle.
Old Jan 20, 2007 | 01:36 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you think you've got the wire, measure continuity to ground on it while turning the door key right and left. There's no need to remove the door panel.
Old Jan 20, 2007 | 02:12 AM
Bubba91's Avatar
Bubba91
Now for some reason it's blowing door lock fuses?
Old Jan 20, 2007 | 08:27 AM
Hooked on Vettes
The door lock system is called the 5 wire reversal rest at ground.
You cut a Light Blue wire and insert a spdt relay in its path.
You also cut a Black wire and insert a spdt relay iin its path.
You must have picked the wrong wires or wired it wrong since you're blowing the 15amp. power lock fuse..
Old Jan 20, 2007 | 03:37 PM
Bubba91's Avatar
Bubba91
I'm not sure I understand .
I checked the wires at the kick panel w/ a test light and found the lock and unlock, the 12v constant to the door locks, the fasd wire, and of course the main 12v constant and good ground.
I even tried reversing the lock and unlock wires.
I don't know about spdt relays, could you explain the 5 wire reversal at ground please?
Old Jan 20, 2007 | 03:51 PM
Hooked on Vettes
Check your pm box.
Old Jan 20, 2007 | 08:42 PM
CentralCoaster
Bubba, you need to check your Helm manual to see if your car uses a pulsed 12V signal or a pulsed ground to activate the locks.
If you try to mix the two it can blow the fuses every time. Take what the alarm system gives you, then check the wiring diagrams to figure out what part of the circuit you can tie into. Worst case, you'll need an additional relay to change the signal.
Old Jan 21, 2007 | 01:34 PM
Bubba91's Avatar
Bubba91
Thanks everyone
To Need Help... Wires under dash
