Master Cylinder reservoir
Old Jan 20, 2007 | 08:02 PM
macfos's Avatar
macfos
Default Master Cylinder reservoir
I have a leak at where the master cylinder reservoir and the little hose connect.
I have been able to find new and remann'ed complete master cylinders, but I don't need the entire thing. Does anyone know where I can get the reservoir only for a 94 C4 coupe?
Thanks for any advice. I have looked around without much success.
macfos
Old Jan 20, 2007 | 08:06 PM
julie32's Avatar
julie32
Try GM parts direct.Its easier if you have part #
Old Jan 20, 2007 | 08:29 PM
macfos's Avatar
macfos
I don't have a part number. Anyone know how I can find the part number for a master cylinder reservoir for a 94 c4 base coupe?
Thanks..
macfos
Old Jan 20, 2007 | 10:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Contemporary Corvette (link on my site) has:
P/N 39061, '95-'96 MS Resevoir - '95 LT1, $20.
You may also want to ask about the resevoir groumets too.
Old Jan 22, 2007 | 07:58 PM
macfos's Avatar
macfos
I ended up getting the part at the local Chevy dealer for $28.50 if you can believe that. The O-ring set was $4.
Great deal!!
macfos
Old Jan 29, 2007 | 12:57 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Great deal!!
macfos
Can you give me the part number as my plastic reservoir is cracking and I need a new one. Mines a 1993, but should be the same.
Old Jan 29, 2007 | 01:15 PM
wro87's Avatar
wro87
I went to my local dealer (Have been GREAT GUYS for 20yrs to work with) and we ordered two plastic Reserviors and orings to replace the single unit on my 87 less than $30 bucks for all and took about 10mins to put on. We sucked all the fluid out of the old one and some saran wrap and paper towels below it. Took a little effort to pop old ones of and used a big socket to put new ons on refilled them let set over night and then drove fine with out any problems. Did take it in next couple of days and had them vaccum out the rest of the brake system for a complete flush. Noi problems. wro87
To Master Cylinder reservoir
