Doing a rebuild on my '85 and wanting to swap to a slightly more mild cam. I found what looks to be a knock sensor on the lower right side of the block. My question is will this throw a cel? If so, is it possible to some how bypass??
it will only throw a code if your engine is detonating, and then the computer will retard the timing to eliminate the detonation.
Not something u need if doing a quarter mile, but something u need if it's a daily driver.
