92-96 non-engine performance mods?
Old Jan 21, 2007 | 04:50 PM
StealthLT4's Avatar
StealthLT4
Default 92-96 non-engine performance mods?
Hey guys,
I'm planning on buying a 92-96 corvette this summer, and for budgeting purposes, wanted to know some worthwhile modifications to do. I'm mainly concerned with handling, as the ones I've driven felt kind of mushy around the turns.
I'm planning on putting an LS7 ('07 C6 engine) into it in a year or two, so I want to focus on non-engine stuff right now. But I'd also be interested in cheap engine mods.
Not really looking for anything in particular (except suspension), just anything that's good to improve on these cars. Thanks.
Old Jan 21, 2007 | 05:09 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Post this in the autocross/roadrace section.
Other than that, doing a gear swap and making the car lighter will help.
Old Jan 21, 2007 | 05:57 PM
LTxDave's Avatar
LTxDave
Look for a Z51 car, mine handles pretty good for a stock setup.
As for the LS7 engine....if your goal is 500 HP, it would be much easier to buy a Golen 396 LT4 with 520HP for much much less than a new LS7 plus all of the installation hassles.
Old Jan 21, 2007 | 06:58 PM
EvanD's Avatar
EvanD
CF Community Team
With the suspension some really good tires are going to be your best money spent.
Old Jan 21, 2007 | 07:04 PM
neat's Avatar
neat
Tires and shocks are the biggest modification you can make to the handling of the cars.
Old Jan 21, 2007 | 11:07 PM
90Z51's Avatar
90Z51
Old Jan 21, 2007 | 11:14 PM
Lone Ranger's Avatar
Lone Ranger
C4 Camber Brace.
Old Jan 21, 2007 | 11:42 PM
StealthLT4's Avatar
StealthLT4
thanks for the replies. Where's the autocross/roadrace section? I didn't see it, under C4 at least. I was thinking shocks, springs tires, maybe lighter weight wheels. What would be some good examples of these to look at?
I'm coming from a 2002 honda civic, where there's so much information on what to get its ridiculous, so going to an older car its kind of hard to find information on what things perform well. Thanks everybody.
Old Jan 22, 2007 | 12:05 AM
96 lt-4's Avatar
96 lt-4
Originally Posted by Lone Ranger
C4 Camber Brace.
the cross frame and cross bar would tighten it up a bit.shocks,tires,larger anti roll bars and new springs if you want to get jiggy with it.sorry i had a moment.
Old Jan 22, 2007 | 10:47 AM
smearig's Avatar
smearig
www.vbandp.com
Forum vendor of brake and suspension parts. You could go nuts with the stuff from this site.
Old Jan 22, 2007 | 11:44 AM
Bad Karma's Avatar
Bad Karma
Definately get some good rubber on her, I plan on going 18" wheels when I'm ready to replace.
Suspension there is a ton of parts out there. Start browsing the sponcered links on the side, there's plenty of parts available.
You can go to Vette Brakes & Products, and get a lot for your leaf spring sucpension, including replacement and upgraded leaf springs. A good set f shocks. Bilsteins are good, or you can get adjustable shocks from QA1 or Koni. There are polyurathane bushing kits available. Bigger sway bars, are avilable, and you can get adjustabl;e heim joint end links. http://exoticmuscle.com
You can also do a conversion to a coilover shock set up... but please do a search and read up before you post a question on this... there are strong opinions on both sides of this fense.
Depending on how deep you want to go into it, how much money you want to spend and if you Vette is going to see any serious track time. You can get adjustable suspension parts: trailing arms, toe rod, etc...
Check out http://www.r-dracing.com/ for porducts to help stiffen up the chassis.
I own a Mitsubishi Eclipse as well... let me tell you the best thing about driving the Vette compared to the 4 banger... TORQUE!
Old Jan 22, 2007 | 12:42 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You can help good tires even more by going to a slightly-wider wheel, as well.
Sending the driver to a good performance driving school will probably net the greatest benefit/cost ratio.
Larry
code5coupe
Old Jan 22, 2007 | 12:45 PM
NGK's Avatar
NGK
C4 Camber Brace.
:iagree It stiffens up the car. Also good shocks. Possibly look into lowering your car. I dont know how much that would help though. As for tires, I hear the Michelin Pilots are pretty good. Also the BFG Pro-Force.
Old Jan 23, 2007 | 01:15 PM
StealthLT4's Avatar
StealthLT4
Thanks! I'll definitely check out all the vendors here. I'd love to go to a driving school, but I'm at the U.S. Naval Academy, so really no time to....I might try over my summer leave though. I live fairly close to Virginia International Raceway, so I might be able to find something there.
To 92-96 non-engine performance mods?
