1996 differential fluid
Old Jan 26, 2007 | 09:25 PM
bogus's Avatar
bogus
hm... I find it facinating that we hate AZ for much more than cleaning supplies, but use their online tech support?
Old Jan 27, 2007 | 12:01 AM
slicked25's Avatar
slicked25
I guess they coppied word for word and picture for picture with Chiltons or Vice Versa. I hear ya though.
Old Jan 27, 2007 | 12:02 AM
bogus's Avatar
bogus
I am not surprised... Chiltons and Haynes are ok for some uses, but for the Corvette, the cars are just to complex.
Old Jan 27, 2007 | 12:53 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Autozone is wrong again as usual. But this time they at least got points for effort.
Old Jan 27, 2007 | 01:05 AM
hippy's Avatar
hippy
Very possible, but the local Autozone has a cute girl working there. Small on the hoots but very cute ***. Oops, this is off topic material.
Being a betting man I would guess less, much less, than 1% would have drilled their diffs for a drain plug. Either pump it out or separate the pumpkin from the batwing.
You say you know the fill plug is crossed, did you try a little heat on it, are you using a 3/8" drive ratchet? How many miles on the car, if it's low I would seriously doubt that plug has ever been out.
Sometimes when you try to remove bolts, plugs or whatever and you'd swear Godzilla put them in. I just went thru this with brake calipers. Tighter than a MOTHERFKr, a little heat later and they came out so easy.
Old Jan 27, 2007 | 01:47 AM
Trog's Avatar
Trog
As a related hi-jack to this thread. Where are folks buying the diff. additive? GM only or 3 party?
TIA
Old Jan 27, 2007 | 02:00 AM
bogus's Avatar
bogus
I only use the GM stuff. I use Mobil dino gear oil.
