I went to buy gear oil for my differenetial (1996), but couldn't find Castrol Syntec Gear Oil. I ran into Redline which stated it was good for Hypoid gear differentials.
1. What are hypoid differnetials (vs. Spiral)? Is that we have?
2. For the Fluild (other than Castrol), any recommondations? (Redline, Mobil1, ...)
In my 1989 I used the stuff from GM. Alot of people like to discount there differential fluid, but its been the only fluid I haven't had a problem with.... yet.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The curved gear teeth in all modern differentials are hypoid.
Most any premium, synthetic gear oil intended for automotive differentials, of the proper weight, will work fine in your C4's differential.
They may need the LSD additive, however....
I upgraded the diff in my C5 to a DTE stage 2 setup with 3.90 gears. DTE requires Redline in all the differentials they build to maintain their warranty. When I bought my C4, I changed all the fluids and put Redline plus the GM LSD additive in the diff.
DG
There is a reason for that, the GL rating is not suitible on the oil they are talking about.
Getting pissed......
In figuring out if I need to add the GM additive, here's what I've found:
-Mobil 1 says:
"...contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required."
"most applications"
-Royal purple says:
"All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary."
C4 are hypoid (not cone), right?
-Redline says:
"It contains friction modifier which is recommended for limited-slip units. "
Ok
Do you guys add the additive anyways?
Harmful if added anyways?
Surely the best amount of additive is the least required to prevent chattering. If people are running Mobil 1 or Redline with no additive and no problems, that must be better, right?
One reason why it would be better is the composition of the lube. The diff takes 2 containers of GM lube and 1 of the additive. The additive is 4 ounces. The GM lube is in 23 ounce containers or 46 ounces for two. That's 50 ounces in total or a lube that is 8% additive. If someone uses 2 containers with Mobil 1, that is 8 ounces of additive and 42 ounces of Mobil 1, a 16% additive mix.
And, of course, the GM lube is not GL-5, it is GL-4. There is a phrase on the bottle that suggest that it is maybe a GL-4+ because it says that some GL-4's won't be good enough.
I use Castrol Synthetic 80w140 with no additive, no issues with chatter or anything else for that matter. It says on the label of the Castrol Synthetic NOT to use any additive at all.
Chatman, that is some interesting info you state there about what is writen on the bottle, ive honestly never looked at one long enough to read the print. Thanks mate
Back in 1996 (or other years for C4), GM is going to recommond their fluid. However, their fluid does not contain the additive as it most likely used in other differentials. So, because our differentials are hypoid/limited slip, GM produced an additive (fricition modifier) and it is required (back in 1996) for use with their fluid.
Present time, most differentials are hypoid/limited sillp and therefore most of the aftermarket fluilds (redline, mobil1, castrol,...) already have such friction modifiers since that's the majority of the market.
So I would guess its okay to "believe" the aftermarket labels ("already contains friction modifiers"). I thought maybe our differentials were something above others (that's why the additive), but a hypoid limited-slip differential is a hypoid limited-slip differential. I think the aftermarket that state it already has the additive will be fine.
In my Impala SS It sounds like someone is kicking the back bumper, which backing up, moving slowly, or going around turns. Its an excellent excuse for new 3.42 Gears though!!
