Replacment MAF Sensor Question
Old Jan 22, 2007 | 04:40 PM
Danspeed1's Avatar
Danspeed1
Default Replacment MAF Sensor Question
Need to replace the MAF on my 1989 Vette. I found one for a reasonable price, but it only has the screen on the air inlet side. Guy says that thats they way it came from Corvette Central when he purchased it. Is this correct
I did the screen removal modd on mine,... wasn't all that please with the results. Want to make sure this one is an OEM fit!
Dan
Old Jan 22, 2007 | 05:10 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
never seen a stock one with only 1 screen, but i've never seen them all.... i just have the front (air side) screen, back to TB removed with no problems.
Old Jan 22, 2007 | 05:13 PM
tequilaboy's Avatar
tequilaboy
One word of caution:
If its a Micro-Tech MAF, expect to have some calibration issues. They tend to overestimate flow at moderate to heavy throttle.
The Micro-Tech MAFs only have 1 screen and a circuit board with a foil instead of a hot wire for sensing flow. They are sold under several brand names.
I have one in my car, but I have also recalibrated my chip to make it behave like my OEM Bosch MAF. Fortunately I had plenty of scan data from my old MAF available so I could recalibrate the Micro-Tech to be a reasonable match.
Old Jan 22, 2007 | 05:20 PM
Danspeed1's Avatar
Danspeed1
It might be all in my head but I am pretty sure I feel a little bog down low when I punch it. I know how critical MAF sensors are but with all the buzz on the forums I figured I would give it a try. Should have used better judgement. I really don't want ANY calibration issues so I will look for a used one off of a 89.
DG
Old Jan 23, 2007 | 12:45 AM
tdr1919's Avatar
tdr1919
Dan
Get a Carquest remanufactured (Bosch) paid $189.00 with the core
works great
Old Jan 23, 2007 | 01:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Look for a used one from an '86-'89 F-body car, I'm still running the MAF from my old '86 IROC in my '88 Vette.
Old Jan 23, 2007 | 01:45 AM
RRT vette's Avatar
RRT vette
I don't think any of the OEM ones come with just one screen. As suggested look for a used one or just get a remanufactured one.
Or if the price is right, buy the one you mentioned, make sure it works first.
To Replacment MAF Sensor Question
