Dyno Manipulation ??
Old Jan 23, 2007 | 03:25 PM
5abivt's Avatar
5abivt
Default Dyno Manipulation ??
What happens if you dont input the correct weight of the vehicle on a mustang dyno ? If a c4 weight roughly 3450 lbs what happens if you tell the dyno the car weighs 3100 or even 3700 ??
Old Jan 23, 2007 | 04:14 PM
LT4POWR's Avatar
LT4POWR
I believe (could be wrong) that higher weight = more hp/tq.
Old Jan 23, 2007 | 04:49 PM
C4Techie's Avatar
C4Techie
Since you aren't trying to accelerate the weight of the car while it's on the dyno, I can't imagine it makes any difference.
Old Jan 23, 2007 | 05:20 PM
zelement's Avatar
zelement
It won't make any difference. The only way that I know to manipulate the dyno to read higher number is to input a higher temperature.
Old Jan 23, 2007 | 05:33 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I have a friend who ran a dyno for some years...he told me he could make it show whatever rwhp and tq he wanted to...he also told me that some shops who did mods and had a dyno would "tweak" the dyno to show nice gains for the mods they installed...
Old Jan 23, 2007 | 09:07 PM
cplonner's Avatar
cplonner
Guys that do that kinda of stuff should have their buisness's shut down. I have had it with people that rip other people off.
Old Jan 23, 2007 | 09:14 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
, hang the ****'s
Old Jan 23, 2007 | 09:36 PM
85vet's Avatar
85vet
Cruise-In V Veteran
On a mustang - the lower weight gives higher HP & Torque #'s.
I use to go to a mustang dyno and we ran it at 3300lbs(Stock), then ran it at 3100, do to weight reductions. The dyno does use the #'s in it's HP calculations and same day, withen minutes the lighter weight = higher HP & torque #'s.
Old Jan 24, 2007 | 02:00 PM
5abivt's Avatar
5abivt
I was thinking the same thing. If the weight is entered lower then the load on the drum is less and the engine may spin it easier which tricks the dyno into thinking it has more hp. On the other hand, what if an LS7 was placed in a pickup truck, and dynoed the same time as a c6. the truck will surely weigh 2000 lbs more... but should theoretically have the same hp rating.
I'm starting to believe it doesn't have an effect on the #s and the load just helps for real time tuning on the dyno, like for timing etc.
Old Jan 25, 2007 | 02:27 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
TJwong would be good to answer this question.
You can't fool a dynojet unless you screw with the weather station. When you do that you can see the inflated correction number. IE a normal correction would be 1.02. If all of a sudden your final run is corrected 1.06 you know you have some foul play.
Old Jan 25, 2007 | 03:24 PM
4DSZR1's Avatar
4DSZR1
Does the engine know what the vehicle it's in weighs??? If I take a truck engine and drivetrain out and install it in a Sunbeam Tiger, dynoed it? Does the HP change???
Hell no.
Old Jan 26, 2007 | 12:41 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Your probably correct. It has been a long time and the weight change might have effected the 1/4 mile et numbers and not the hp/tq numbers.
Old Jan 26, 2007 | 11:09 AM
BigLee's Avatar
BigLee
the STATIC vehicle weight should have no impact on the tq/hp figures obtained from the dyno...
only changes in ROTATING mass could influence the chassis dyno.
for example, installing lighter wheels and tires onto the rear of your car would cause slightly higher readings...
Old Jan 27, 2007 | 08:50 AM
cplonner's Avatar
cplonner
If you take 2 vehicles and they have the same engine and drive trains, they will both put the same numbers to the wheels. Now if you run them at the track, the lighter vehicle will have the better times. Am I wrong?
Old Jan 28, 2007 | 09:22 PM
5abivt's Avatar
5abivt
yes ur wrong. A mustang will always lose no matter what...
To Dyno Manipulation ??
