copper header gaskets are they hype?
Old Jan 23, 2007 | 08:17 PM
ittybittyfds's Avatar
ittybittyfds
Default copper header gaskets are they hype?
ok all you header guys out there.
are the copper gaskets gimmick or should i go get a set before my install?
Old Jan 23, 2007 | 09:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't think copper is required but the gasket should have a solid metal core instead of the perforated metal core as some have.
On my '86 IROC I fought with leaks and replacing the perf core gasket till I switched to the solid core and no problems after that.
Old Jan 23, 2007 | 10:29 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I used Percy's on my car.
Old Jan 23, 2007 | 10:50 PM
STL94LT1's Avatar
STL94LT1
I tried the copper gaskets, and never could get a good seal.
Old Jan 24, 2007 | 10:39 AM
Strick's Avatar
Strick
I currently have copper gaskets on mine with headers and they have held a good seal for over 4 years now. I'd say they work well and are worth the extra buck or two.
To copper header gaskets are they hype?
