Best TPS setting for L98?
Old Oct 3, 2001 | 04:33 PM
TPFKATK's Avatar
TPFKATK
Default Best TPS setting for L98?
What is the best high performance voltage settings idle and WOT for an 88 L98?
Thanks.
Harold
Old Oct 3, 2001 | 04:41 PM
scorp508's Avatar
scorp508
Default Re: Best TPS setting for L98? (TPFKATK)
No higher than 0.68v at idle, and at least 4.80v or higher at WOT.
Old Oct 3, 2001 | 05:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Best TPS setting for L98? (scorp508)
I agree with Scrop508.
Old Oct 3, 2001 | 06:07 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Best TPS setting for L98? (65Z01)
I just set mine at .535 V it was at .473 V do you think I should raise it to .580V or leave it alone. The Hayne Manual says 0.0 - .540 V what are the best results at? Thanks.
Old Oct 3, 2001 | 06:39 PM
Vic'89's Avatar
Vic'89
I have mine set at .57v at idle.
Vic
Old Oct 3, 2001 | 09:19 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Best TPS setting for L98? (Vic'89)
Anyone else have suggestions and how about at WOT? Thanks
Old Oct 4, 2001 | 09:49 AM
Aaron's 87's Avatar
Aaron's 87
Idle where the manual says. WOT on mine is around 4 with NO problems. Another case where bigger is NOT better. Just because the TPS can make 5 volts doesn't mean you have to have it for WOT.
To Best TPS setting for L98?
