Weak Starting
Old Jan 25, 2007 | 05:00 PM
murraydeluxxxe's Avatar
murraydeluxxxe
Default Weak Starting
My 88 C4 with only 13,500 miles seems to fire right up when it's cold, but then when it's a little warmer, it takes a little longer. Not real long, but it feels weak.
Any thoughts?
Old Jan 26, 2007 | 12:43 AM
gbody5's Avatar
gbody5
Stock injectors I presume? If so they are probably leaking after 19 years, prone to happen on these L98's. Mine did the same thing when I bought it in 1996 with only 32K miles and it was the injectors. Get the same size for stock GM, should be 21-22 lb. if you get larger Inj you will need to tune for optimum perf.
Cheers
