New GM Crate Engine for 1990
Question: 52cc TB better or am I okay with stockTB, need headers, what kind and where plus exhaust, is the stock distributer okay. The car runs good after 3500 rpms slow off the line until I reach 3500 rpms.Hopefully TB, and exhaust (better breathing) will help, any help would be appreciated.
DESCRIPTION: ENG-330HP HO BASE
Our lowest priced crate engine, the 330 horsepower 350 HO doesn't sacrifice power or durability, it just pumps up the value. With its four bolt main block, nodular iron crankshaft, powerded metal steel connecting rods and light but strong cast aluminum pistons, this engine screams durability. Add to the strong foundation a pair of 64cc Vortec cast iron cylinder heads and a dual pattern camshaft with just a bit of a "lumpy" idle, and you've got the muscle car small block that you've been looking for. Dressed to impress with chrome valve covers and timing cover, this engine will look great between the fenders of your favorite street rod, muscle car or grass roots racer. The cylinder heads on this great little performer use 1.94" intake and 1.50" exhaust valves that are sprung with 5.7 Liter L31 valve springs. The 64cc chambers yield a healthy, but streetable 9.1 to 1 compression ratio. The cam is a modern dual pattern interpretation of the old '65 to '67 Corvette 327 cam. But with more lift and duration on the exhaust side, it does a better job of clearing exhaust from the combustion chamber. We also decreased duration and lift ever so slightly on the intake side to build more cylinder pressure. The result is a cam that makes great torque and horsepower with the 350 HO's compression ratio. This manifold has four bolts, not six, to attach it to the cylinder head. Older six-bolt manifolds will not fit the new Vortec heads.
did you order a chip or have someone tune the car before driving it?
hopefully he can make adjustments to the chip.
Thanks for the info........just looking for HP
the new engine calls for 0* so the mechanic split the difference and set the timing at 5*. Is this a distributer issue or will re-programming the ECM fix the problem? Or do I have the timing set at 0*?
Thanks in advance for the help
PS. Be sure to reconnect the EST and clear the code after setting the timing, each time.
Stock dist. should be more than adequate, dont spend money there.
Save for headers and exhaust, then intake mods. Read my website.
Once you start changing the TPI intake through porting or replacement, you can easily make 350hp. This engine can do that if he modifies the intake, the cam and heads are not mismatched to TPI.
Unless he did, I don't know how any of this works. Hopefully his mechanic didn't run off with a new set of Vortec Heads, but if he swapped them out for the 113's, that might explain why it's crapping out at 3500 rpms, especially with the Big Mouth Manifold and the stock runners.
1.) Timing
2.) Re-program the ECM
3.) Fuel rails & 24lb injectors
4.) Headers and exhaust
This will probably be a two stage process 1 & 2 first then at some time later 3 & 4. Once 4 is completed re-program the ECM again.
Once completed I may add additional componets to tweek the new GM engine. Thanks for all your help
