My left headlight is not sitting flush with the hood. There is also about 1/4" of play, and this is the same as the gap between top adjustment screw and the underside of the hood. When I put pressure on the headlight to make it flush the adjustment screws then touch the underside of the hood and the headlight is flush, so they are adjusted correctly. Is there some other adjustment, or way to fix this so the headlight sits flush.
I have a picture of it, how the heck do I insert an image into a post.
