" stealth ram rev range please"
Old Jan 26, 2007 | 07:44 PM
sxyvet's Avatar
sxyvet
Default " stealth ram rev range please"
hi guys,
i heard that as advertised the holley stealth rams rev range is
from idle to 6,000 rpm qouted from "jegs" and "summit".
then i heard from grumpyvette that the range is from 3,500 rpm to 6,500 rpm, so which range is it suited to please?
would you class the stealth ram as an all rounder or more mid-top end?
r.e "super ram" what rev range is that start to finish at please?
thanks guys
cheers
glen
Old Jan 26, 2007 | 11:39 PM
sxyvet's Avatar
sxyvet
bump,any one know please?
cheers
glen
Old Jan 26, 2007 | 11:45 PM
88BlackZ-51's Avatar
88BlackZ-51
it all depends on what heads and cam?
use the search options on this website. you need to do some research.
hippy's Avatar
hippy
What cam, what heads, what compression. The same heads with different components down stream will peak at different RPMS.
Old Jan 27, 2007 | 05:11 AM
Fastmax32168's Avatar
Fastmax32168
I think you will probably find more info on the Stealth Ram over at Thirdgen.org. The manifold doesnt fit under a stock vette hood so there arent going to be a ton of people here that have actually used one.
Roy
Old Jan 27, 2007 | 05:49 AM
rodj's Avatar
rodj
Should learn how to use Google
www.eecis.udel.edu/~davis/z28/winter01/dyno/
MiniRam_(383)_vs_HSR_(383).html[url]
dyno021105/webpage021105.html[url]
www.stealthram.com
www.geocities.com/MotorCity/7610/dyno.htm
http://www.thirdgen.org/techboard/al...t-efi-intakes/
Old Jan 27, 2007 | 12:14 PM
sxyvet's Avatar
sxyvet
[QUOTE=rodj;1558697550]Should learn how to use Google
what do you think you mean man,how to use google?
do you think im stupid or some thing and i dont realise you are being sarcastic!
i know how the f*ck to use google!!!!!!!!!!!!!!!!!!!!!!!!!
so dont be a f*cken smart *** if you know what i mean ,ok!!!!!!!!!!!!!!
and by the way i have done alot of searching and reading on stealth for your info and there are so many different answers to one iam after who knows what to belive!
dont start a flame war with me.
so there you go!!!!!!!!!!!!!!!!!!!!!
alrighty then.
Old Jan 27, 2007 | 12:44 PM
LD85's Avatar
LD85
FWIW> When I dynoed my Miniram the HP peaked at 5900 RPM and the HP stayed the same up to 6500rpm then dropped off.
If you dont have forged internals, "I PERSONALLY" would not go above 6000rpm.
Some guys do go up to 6500 with stock parts,
Lastly, 6000 or 6500,,, you talking about the blink of an eye
And you cam will play a roll in how high you can go before its over.
Old Jan 27, 2007 | 12:47 PM
88BlackZ-51
[QUOTE=sxyvet;1558700165]
alrighty then.
Calm down man!
Old Jan 27, 2007 | 02:05 PM
pablocruise's Avatar
pablocruise
" hydraulic rollers will start to float the valves in that range anyways. Besides, the dash tachometer is known to be off from the actual revs. Don't worry about 500 RPM.
With the limited time I ran a stealth and the time I ran a superram, I would class the stealth is an "all-arounder" as you describe it. "
thanx
cheers
Old Jan 27, 2007 | 05:49 PM
sxyvet's Avatar
sxyvet
hi there 89 paul in cal and larry (ld85),
thank you guys for your imput/help!
at least you guys arent stupid smart *** sarcastic towards me!
there is no need for smart *** dick heads on this site regardless of what is being said,asked,told or what ever!
cheers
glen
Old Jan 27, 2007 | 08:07 PM
rodj's Avatar
rodj
"there are so many different answers to one i am after who knows what to belive!"
Did the links I posted help?
As with many questions there are multiple answers and opinions so it is up to you to decide which one best suits your situation.
"so there you go!!!!!!!!!!!!!!!!!!!!!
alrighty then."
Must be the beer in Victoria
To " stealth ram rev range please"
