OIL CHANG LIGHT
Old Oct 3, 2001 | 10:15 PM
righton's Avatar
righton
Default OIL CHANG LIGHT
How do you get it turned off
Old Oct 3, 2001 | 10:24 PM
RichS's Avatar
RichS
Default Re: OIL CHANG LIGHT (righton)
Look in your owners manual it's in there. Or do a search here it was just posted about a week ago.
Old Oct 4, 2001 | 12:30 AM
Red Dwarf's Avatar
Red Dwarf
Turn ignition "on", donot start.
Press eng/met button, within 5 secs press eng/met again, within 5 secs press & hold gauges or range until oil light goes out.
Old Oct 4, 2001 | 12:48 AM
corvette1990's Avatar
corvette1990
Default Re: OIL CHANG LIGHT (lou sylvestri)
You forgot the....and change the oil and filter......
Old Oct 4, 2001 | 12:24 PM
Red Dwarf's Avatar
Red Dwarf
Sori about that chief! :cheers:
Old Oct 5, 2001 | 11:10 PM
Admiral Fairway's Avatar
Admiral Fairway
Turning off the change oil light
1) Turn the ignition "ON", but do start the engine.
2) Press the "ENG/MET"button and release, then, within 5 seconds, press it again.
3) Within 5 seconds of step 2, press and hold the "GAUGES" button. While the button is held, the "change oil" indicator will flash.
4) Continue holding the "GAUGES" button until the "change oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds. If it does not successfully reset, turn the ignition "OFF" and repeat the procedure from step 1.
To OIL CHANG LIGHT
