help with fans/car gets hot
If he floors it it won't up shift until near redline (5700), that is what it is supposed to do.
Use test jumper to ground some terminals here, there should be a nice little ground near the horn on that side. Clip one end to ground, use a paper clip unfolded clipped to the other end of the jumper to go into the underside of the relay plugs. We're trying to ground some terminals while the relays are still plugged into their sockets, so what ever way works best for you.
With the key turned to "run" ground the dark green wire's terminal on relay #1, the fans should run at low speed.
Then with that jumper still grounding that terminal, do the same with another jumper and paper clip for the dark blue wire's terminal, it can be found on either relay #2 or #3 it doesn't matter which one. The fans should then run at high speed.
Make sure to check fan fuse #29 also, it supplies ignition voltage to the relay coils. It's in the right side of the dash on the passenger side.
If the fans check out by all means do the things suggested above in the earlier post, these cars have an area that does clog up with debris between the radiator and condenser, sometimes the front of the condenser when looking from under the front of the car in the air scoop area gets nasty also.
If that turns out to be clean and not an issue, run the car and let it idle. Hit the gauges button until your looking at the coolant temperature on the digital display.
Let it continue to idle until it gets to 230 and the fan(s) should come on, don't let it go too much further than that if they don't come on. Maybe 240 at the MOST. When you see the digital gauge displaying 225 see if the analog gauge is reading about the same.
I'm assuming when you say it goes to 260 you're looking at the analog gauge? This is already too hot and the fans should have come on before that. Don't let anyone tell you this is normal, and they will, because this is not normal! If the fans are programmed to come on at 230 or 228 the temperature should go down and we should NEVER see 260 on either gauge!
Yes we have had MANY heated discussions about the cooling or lack thereof in LT1 cars. I want to see if there is really a problem with all these cars or we just think it's too hot.
Like I said earlier, compare the two readings, if the digital gauge (the one the PCM uses for fan control) is reading much lower than the analog gauge, I believe we have a sender that is falling out of calibration on many of these cars and sending erroneously low temperature readings. Therefore the PCM thinks the engine is cooler than what it actually is and sits there and waits until it sees what it believes to be 230. Meanwhile the correct temperature on the analog gauge is going past 250 to 260. TOO FREAKIN HOT!!!
If you find this to be the case ask your Dad if he would be willing to buy a new sender, it's the one installed into the water pump body. I'm truly starting to believe these senders are going bad causing many of us LT1 owners to think we need to take additional cooling steps or remedies.
The accuracy of this sender can't be stressed enough so don't buy a cheapie, get a new factory correct GM sender for the car.
I had this problem and may have masked the problem by installing a 160 t-stat and programming my fans to come on sooner. This did bring the temperatures down dramatically however now I can't see for myself if a new sender would have cured my problem without undoing a lot of stuff. Furthermore I don't have any way of setting my fans back to stock settings. They were changed by PCMforless.
