Shifter moving when cluth is engaged
Old Oct 3, 2001 | 11:00 PM
Hammer's Avatar
Hammer
Default Shifter moving when cluth is engaged
I never noticed this before. When engaging the gear the stick moves slightly to the left.
Is this normal or is something loose?
Jim
Old Oct 3, 2001 | 11:12 PM
Rich_01659's Avatar
Rich_01659
Default Re: Shifter moving when cluth is engaged (Hammer)
something is loose! my stick moved everytime i stepped on the gas, it is my first vette i thought this must be normal. finally (year later) clutch failed, took the car in and the tech said the bolts were coming out of the bell housing. new clutch and tight bolts AND THAT STICK DON'T MOVE!!!!!
Old Oct 3, 2001 | 11:29 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Shifter moving when cluth is engaged (Rich_01659)
Might also want to check that your driveline support beam bolts are torqued to spec. I understand that if these are loose, the shifter may move under acceleration.
To Shifter moving when cluth is engaged
