86, rides low in the front?
Old Oct 3, 2001 | 11:33 PM
frank moran's Avatar
frank moran
Default 86, rides low in the front?
anyone experience this, everything appears ok except there is not a lot of clearance in the tire to wheel opening??? car does not appear to have any mods.
Old Oct 3, 2001 | 11:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 86, rides low in the front? (frank moran)
Maybe that's because the rear has so much clearance (or maybe a weak front spring). Measure clearance from top center of each tire to fender opening.
Here's data when mine was stock. Ride Height @center of wheel well:
Left F / R = 26.75” / 28” Rear=+1.25”;
Right F / R = 27” / 28.5” Rear=+1.5".
I dropped the both rears about 1 1/8"- 1 1/4" and she sits level and fills the wheel wells nicely now.
BTW, do you have Bilsteins?
Old Oct 4, 2001 | 01:23 AM
drive it's Avatar
drive it
The 86's do sit low in front right out of the factory. As long as the tires don't rub don't worry. If they do rub the spring may be soft. If you want to raise it you need to add some shims.
Old Oct 4, 2001 | 07:02 AM
MDC9966's Avatar
MDC9966
Where would you put shims, I've already had the front nose and clam off and could only adjust that area to square the body lines. Anyway, I use the old finger width Method. Holding your hand out I can get the width of 3 fingers between the top of the tire and center of the wheel well opening on the rear and 2 on the front, The front is between 2 and 3 but roughly that's it. I've seen them all over the place and there is a lot of difference between cars. If your shocks are worn I'd replace those first. I restored a 65 mustang and lifted the front almost an inch with only new shocks. Hope this helps.
Old Oct 4, 2001 | 10:22 AM
tacblu's Avatar
tacblu
I have an '86 also, and it sits lower in the front. It seems, from what I've been able to gather, that they just sit low from the factory. Mine only has 28,000 miles on it, so the spring is in good shape. If you don't have any tire interference, I'd just leave it alone. The only problem I had was my front spoiler was always hitting the ground. I solved this by triming one inch from the bottom of the spoiler. I now have plenty of clearance and it did not have any effect on my cooling. Hope this helps.
Old Oct 4, 2001 | 02:55 PM
snaketr's Avatar
snaketr
Actually you may have a problem. 86's do not sit that low, and this problem I have only noticed it on 86 adn 87's. There is a rubber cushion that is glued to the spring, well they dry rot and collapse and this is what causes the front end to drop. Unfortuantly you will have to buy a new spring. The only other thing you could try is to call Vette Brakes and see if they could sell you one of the cushions that they put on there new springs.
Old Oct 4, 2001 | 05:41 PM
frank moran
Default Re: 86, rides low in the front? (65Z01)
thanks for the data, no bilestiens, probebly origianal shocks car has 76K and sits at 26.5", I think I'll leave it alone for now,.
Old Oct 4, 2001 | 05:44 PM
frank moran
Default Re: 86, rides low in the front? (tacblu)
I agree, I'll leave it alone it's at 26.5 as noted by one of the other responses. thanks
Old Oct 4, 2001 | 08:09 PM
HiRiser's Avatar
HiRiser
New Bilsteins raised my font up to 27"- about an inch. Maybe your shocks are gassed out.
To 86, rides low in the front?
