air pump effect on 02 sensor
Old Oct 3, 2001 | 11:48 PM
TJR's Avatar
TJR
Default air pump effect on 02 sensor
The o2 sensor measures air/fuel ratio. The air pump injects air into the exhaust manifold upstream of the o2 sensor. Since the air pump adds fresh air to the exhaust stream, it should increase the air/fuel ratio measured at the sensor. I'd think that the computer would be calibrated to this. By removing the air pump system, would you be throwing off the o2 readings? With the fresh air no longer being added to the exhaust, wouldn't it cause the computer to think "rich" and react by leaning the fuel supply?
I've searched the web and gotten some great info on o2 sensors and air injection systems, but nothing about the relation between the two.
I hope someone can provide some input. Thanks in advance.
Old Oct 4, 2001 | 03:39 AM
nsimmons's Avatar
nsimmons
Default Re: air pump effect on 02 sensor (TJR)
I know when you go wot, the air diverts from exhaust and dumps directly into the air cleaner assembly..My car had a leaky diverter valve when i bought it, it would sometimes back fire and ran rich from the fresh air, being introduced into the exhaust when it should not have been..the air is delivered to the manifolds when the car is cold, leaning the mixture to induce a rich condition for warm up. when its warm, the air is diverted to the cat, past the o2 sensor, so it has no effect of mixture..hope this helps..
Old Oct 4, 2001 | 09:18 AM
Carl90's Avatar
Carl90
On my 90, air stops getting pumped into the exhaust manifold at warm up. When the ECM goes into closed loop where it is using the O2 sensor for feedback, air is being pumped into the cat only. Air pump has no impact on O2 readings.
Old Oct 4, 2001 | 10:25 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: air pump effect on 02 sensor (Carl90)
That's it. The diverter dumps air into the exhaust manifolds during warmup to help heat the O2 sensor to accelerate closed loop running. After that air is dumped into the cat, or to the outside. Once in closed loop mode air is not injected into the exhaust manifold, unless there is a fault in the diverter system.
Old Oct 4, 2001 | 11:18 AM
TJR's Avatar
TJR
Default Re: air pump effect on 02 sensor (nsimmons)
...when its warm, the air is diverted to the cat, past the o2 sensor, so it has no effect of mixture..hope this helps..
Thank you both, that's exactly what I wanted to hear.
To air pump effect on 02 sensor
