Air Mix Temp Door Motor Replacement
It seems that the air mix door motor is not moving the door between the heater core and the evap coil. I have it out, but have no way of testing it. The C68 Electronic Temp control self test all came back good with no failure codes, so I am assuming that this is good as this is what drives the motor.
Has anyone had to replace this part before?
Thanks,
LannyL81
I had the motor module in my hand while I went between hot and cool on the temp setting...and the motor never moved. I can rotate the air mix door by using my fingers, so I now that it is not jam'ed or anything. I am not able to turn the motor with fingers though.
According to the FSM schematics there are two battery inputs into this motor with resistors (of unknow value), so I do not want to put +12Vdc across it to try to test test it.
Guess I will just get a new one and see what happens. Would not be the first time I have replaced a perfectly good part.
LannyL81
Then, if the drive voltages seem correct you could be assured that the motor is bad.
Took mine apart and applied +12Vdc and the was able to see the motor moves in both directions. I check harness and it is good as well. I still need to check the circuit board within the motor module for continunity between the motor itself and the harness connector pins to make sure I do not have a break there.
If the circuit board is good, then what is at fault in my car and probably James in MD is that the HVAC Programmer has failed, as it provides the power to the motor module.
The HVAC head control should be reporting a failure as there is a positon feedback circuit within the motor module that tells the systems that the door is not moving.
Putting the HVAC into diagnostic mode, selecting the temperature door test should show this.
But I did have heat this morning as I have the motor module off and I can move the air mix door using fingers. So I just put it all the way to the heat position and drove to work WITH heat. Of course I could not regulate the temp with the temp setting...just had to open the window.
I plann on pulling out the HVAC Programmer and checking solder connections first before getting a reman one ($120). Getting to the HVAC Programmer is not fun..
James in MD....I suggest you check the temp door values on your HVAC control head. If you need instructions on how to, just ask.
LannyL81
Mine (C68) has always blown lukewarm at any temp other than max or min. At max it blows full hot. At min it blows full cold. In between is pretty much one temperature.
I've figured it was probably a bad interior temp sensor but it hasn't ever bothered me enough to dig into it. This winter I have the dash apart and will be investigating this problem.
Guess the HVAC Programmer is working fine. Only thing I can think of was that the solder connections on the motor are not making good contact and my probing around on them clean the connect enough to get it to work.
I plan on hitting the two solder joints with a solder iron to reflow the joints and test it again in the car. The motor housing itself is very oxide which I think is from condensation dripping down the temp door pivot shaft and into the motor module. This motor is just a little dc motor. I will post a picture of the insides later tonight, as I took a picture of it before I took it apart.
Here is what the air mix or temperature door motor module looks like inside
http://i136.photobucket.com/albums/q...1/P1280003.jpg
LannyL81
Just a thought.
-Mike
Access to the motor module is obtained by removing the passenger knee bolster. Then removing two screws and it drops out. The screws are 5.5mm or 7/32 hex head.
I put the HVAC into diagnostic mode and then into the temp door test #31 or #34 (not sure which now). And the display was to show between 100 and 200. By changing the temp between 60 and 90 the motor module would move, but the number on the HVAC display never changed like I was expecting.
Oh well...at least the temp door is moving now so I have heat and defrost, which is a good thing.
Later,
LannyL81
