The proper location for an optispark.
Old Jan 29, 2007 | 10:55 AM
VenkmanP's Avatar
VenkmanP
Default The proper location for an optispark.
http://web.camaross.com/forums/showthread.php?t=498873
Old Jan 29, 2007 | 11:20 AM
Ttime's Avatar
Ttime
I wouldn't mind that . The only reason I fear the failure of an opti 1.) The cost of parts 2.) The time to put it in. Other than those two, it's a very precise ignition system. Probably the best for it's time.
That's
Old Jan 30, 2007 | 12:30 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Hmmmm.... if that has a quartz movement... your timing should always be pretty accurate.
Does it have the optional vent tube on it?
That board will need to be epoxy coated just in case the water pump leaks onto it.
Old Jan 30, 2007 | 09:48 AM
redrose's Avatar
redrose
can we get one of those cast in lead ??...and a couple feet of chain??
then we need to get the perp at gm that came up with the idea to go for a short boat ride on lake mich..
Old Jan 30, 2007 | 09:44 PM
Siveck's Avatar
Siveck
I would definitely put a more reliable clock nearby as that one will likely fail soon.
Old Jan 30, 2007 | 10:03 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
135,000 miles, no opti failure here(it is the second one only because as long as the water pump was out, it made sense to change the opti, but it wasn't due).
Mackey went well over 100,000 with his original opti.
Yeah, I guess it really does suck huh?
Now the early design, yeah I did have a failure there, but it was due mostly because of the car sitting more than it was driven. After all I bought it with 36,000 and I'm the 7th owner. The same thing can happen to a car with a standard ignition. I know because it happened to me already.
Old Jan 30, 2007 | 10:31 PM
Road Agent's Avatar
Road Agent
Old Jan 31, 2007 | 08:20 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Optispark distributors are bloody fantastic. If it fails it no worse than any other distributor system. Its no more likely to fail any more often than any other distributor system.
To The proper location for an optispark.
