Extra inlet/outlet on newpump
Old Jan 29, 2007 | 07:07 PM
Bozzy90210's Avatar
Bozzy90210
Default Extra inlet/outlet on newpump
In doing my Opti I thought I should replace the water pump and thermostat as both have been on at least 5 years. In hooking up the hoses I noticed an outlet on the bottom passenger side of the pump. Now my stock one didnt have this. Its the second pump Ive had to get as the first was cast real bad.
The part number is Fenco P1561.
Anone know if this oulet can be bloked and run as I dont want to get another pump to put on it if i dont have to. Ideas?
Old Jan 29, 2007 | 07:15 PM
Road Agent's Avatar
Road Agent
My 92 Lt1 does not have the extra outlet. Have no idea what year your car is, so unless someone else can chime in. I suggest getting the correct water pump!
Old Jan 29, 2007 | 08:16 PM
ALLT4's Avatar
ALLT4
Sounds like you may have gotten an F body pump instead of a Corvette pump. There is a difference.
Old Jan 29, 2007 | 08:42 PM
Road Agent's Avatar
Road Agent
Did a little checking and found that the later lt1's had the extra outlet on the water pump. I think you can use it but you'll have to use an 95 or 96 upper hose and eliminate the tee used on the early lt1's.
Old Jan 30, 2007 | 02:18 AM
Bozzy90210's Avatar
Bozzy90210
ROAD AGENT: Can you direct me to where you found more information?
To Extra inlet/outlet on newpump
