4l60e Swap Need Help....
Old Jan 29, 2007 | 07:57 PM
123sugey's Avatar
123sugey
Dig
Default 4l60e Swap Need Help....
My Friend Just Installed A 1994 4l60e Trans Into A S-10 Pickup. The Truck Now Has A Carburated Small Block In It.
Question Is : What Does He Need To Make The Trans Shift Correctly And Torque Converter Lockup ?
Thanks For The Help
Old Jan 30, 2007 | 01:34 AM
rebuildman's Avatar
rebuildman
If it truly is the 'E' version, this is an computer controlled (shifted) trans. Which requires the computer and sensors to work. The 4L60e is a distant cousin of the 700r4 which is not computer controlled. The aftermarket does make controllers to do this retrofit.
Old Jan 30, 2007 | 07:41 PM
123sugey's Avatar
123sugey
Dig
Is There A Valvebody Or "trick" That Will Make The Trans Shift Correctly ? And Where Do You Buy The Lockup Control Unit ?
Old Jan 30, 2007 | 07:49 PM
Pete K's Avatar
Pete K
I think TCI has a stand alone computer. $550 or so, if memory serves.
Old Jan 30, 2007 | 07:52 PM
123sugey's Avatar
123sugey
Dig
Is There A Way To Convert The 4l60e Back To 4l60 Without The Computer ?
Old Jan 30, 2007 | 07:57 PM
Pete K's Avatar
Pete K
Not that I am aware. With the abundance of 700r4's out there, I would not guess many have tried to convert an electronic trans to a non electronic trans.
To 4l60e Swap Need Help....
