new guy needs help!!
Old Jan 31, 2007 | 09:59 AM
dale2939's Avatar
dale2939
3rd Gear
Default new guy needs help!!
I have a '94 that had a bad clutch master cylinder. i was having to top off every week with fluid. Replaced with new m.c. now cannot for the life of me get it to bleed. After talking to a friend that owns a body shop, I am "gravity bleeding" it as we speak. Is that the answer, or if not, is the "power bleeder" the answer? HELP!! I have had the car for 16 mos. and love it, but I bought it to drive, not leave in the drive way on jack stands!!!
Old Jan 31, 2007 | 10:11 AM
CAJUN C4's Avatar
CAJUN C4
Did you bench bleed it before installing? If not,you probably have air in the system.Try bleeding it at the slave cylinder.This should fix the problem.Remember, take the slave off the bell hsg. and be sure the bleeder screw is pointing straight up to allow the air out.Otherwise it could stay trapped in the slave.
Hope this helps.
Old Jan 31, 2007 | 10:18 AM
dale2939's Avatar
dale2939
3rd Gear
Thanks, I'll try that tonight. I have it off, tried to bleed manually, but did not have the valve pointing up. Thanks
Old Jan 31, 2007 | 02:06 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
The FSM also calls for bleeding at the ABS controller behind the drivers seat
Old Jan 31, 2007 | 02:39 PM
CAJUN C4's Avatar
CAJUN C4
I think He's working on the Clutch M/C.
Old Jan 31, 2007 | 09:10 PM
Warp8's Avatar
Warp8
I don't think the clutch hydraulic system is subject to skidding.
Old Jan 31, 2007 | 09:16 PM
94z07fx3's Avatar
94z07fx3
LMAO! you should've seen me when I was learning a clutch at age 14 with a DODGE van that had "three on the tree". I just might have changed your mind about the ability for a clutch to skid!
To new guy needs help!!
