Crash pad removal for ECM access
Old Jan 31, 2007 | 07:13 PM
85RIT's Avatar
85RIT
Default Crash pad removal for ECM access
How do you get to the ECM easily?
Remove the crash pad? How do you do that?
I've had no luck so far. I am still trying to troubleshoot my injector problem, and I am trying to see if I am getting any signal out of the ECM. I am not getting any at the pigtail under the kickpan that I unplugged.
Old Jan 31, 2007 | 07:46 PM
nyernga's Avatar
nyernga
A 10mm socket with extensions. Drop the hush panel, get into as comfortable position under the dash as is possible and remove the two bolts. I did mine a long time ago and it was somewhere between a root canal and a public flogging.
seriously though, it's very doable without removing the "bread box" That in and of itself takes as long as the ECM removal.
Old Jan 31, 2007 | 07:57 PM
wro87's Avatar
wro87
Very duable put with my dam bifolcals had to have the kid do it took about a foot long extension and tilted the set back as far it would go flashlifht is nice.
wro87
Old Jan 31, 2007 | 08:25 PM
85RIT's Avatar
85RIT
Thanks!
Got it.
To Crash pad removal for ECM access
