Rocker Arm Nuts
Old Feb 1, 2007 | 10:07 AM
Chatman's Avatar
Chatman
Default Rocker Arm Nuts
I picked up a set of Crane Gold rocker arms that came without rocker arm nuts. Should I buy something like Mr. Gasket Sure-Lock, Crane Cams rocker arm nuts, reuse original, or do something else? Lots of discussion about rocker arms but I don't find anything on nuts. Thanks in advance.
Old Feb 1, 2007 | 07:11 PM
Chatman's Avatar
Chatman
I was afraid that it might be a stupid question, but I don't know the answer and would like to have everthing at hand when I start this job. Your help will be appreciated.
Old Feb 1, 2007 | 07:15 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If it were me I would call the vendor and ask what they recommend.
Old Feb 1, 2007 | 07:18 PM
rich653's Avatar
rich653
Never a stupid question, I would go on Crane Cam website or Advance Auto and get the nuts that they recommend for those rockers, I'm sure there's others that will work but that way you'll know there the right ones. Good luck
Old Feb 1, 2007 | 07:32 PM
BADDUCK's Avatar
BADDUCK
There must be an echo in here!
Old Feb 1, 2007 | 07:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
He was typing while you were movin' on... jus' lookit the times of posting
Old Feb 1, 2007 | 09:39 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default nutz 2 u
I would use poly locks from summit
Old Feb 1, 2007 | 10:34 PM
rich653's Avatar
rich653
Sorry didn't mean to march in your parade!
Old Feb 1, 2007 | 10:42 PM
Siveck's Avatar
Siveck
I made the mistake of reusing rocker arm nuts on my boat motor and I had to reset the lash after 10 minutes of idling. All of the nuts came loose and the rocker arms started flopping around. Luckily, I caught it before any damage was done. I used some special nuts from a hardware store that were similar to the originals. The threaded hole actually had a triangular shape that would lock onto the studs.
Old Feb 2, 2007 | 06:49 AM
Desert1957's Avatar
Desert1957
Most Quality , repeat QUALITY Roller Rockers such as Crane Golds are machined for their own Poly-lock set up. Stock rocker arm nuts will not stay tight and might even bind on the rocker arm pivot shaft.
If you look closely at the rocker arm pivot shaft you will notice a machined area , this goes up when installing the rockers.(It will mount either way)
You can use any type poly-Locks , but with the investment of the Crane Gold series rocker use Crane Nuts, why skimp on the nuts?
Desert
Old Feb 2, 2007 | 08:46 AM
BADDUCK's Avatar
BADDUCK
You didn't I thought it was funny!
Old Feb 2, 2007 | 08:49 AM
BADDUCK's Avatar
BADDUCK
Desert
If Crane is so great why don't they include lock nuts. Almost every set I looked at included poly locks. Just more of a rip off from crane!
Old Feb 2, 2007 | 09:55 AM
Desert1957's Avatar
Desert1957
If its good enough for the LT4 GS Corvette , makes more Horsepower and Torque , Reduces oil temps , Has less wear on the Valve train and Guides , Who Cares about price , its a CORVETTE!
So you have to buy Poly-Locks , big deal its worth it ....
http://www.enjoythedrive.com/content/?id=9722
Desert (no reply to this post is needed , its just my opinion , that's all )
To Rocker Arm Nuts
