Solid Rear Project....
Old Feb 1, 2007 | 02:48 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Solid Rear Project....
Ok thought I would give you guys an update on the solid rear project.
With everything going on not much has happened but I do have the base list of things I am going to be ordering.
4 link setup with chromoly rods ends ~$500
Qa1 Coil over setup ~$600
Moser 12bolt, spool, 4.11 pro gears, 33 spline axles ~$2000
Pan Hard Bar ~$200
Going to be going with the stock rear breaks, think if money permits I am going to be going to manual strange master cylinder and a set of aerospace front brakes.
But as you can see I am at about $3300 for the parts alone, which should make a real reliable and good working system. It would be pretty hard to do it for under that price...
I will keep you all posted as I start the project. Time is the only thing I need to find.....
