1991 Fuel Pump Relay
Old Feb 2, 2007 | 12:03 AM
DeBaGo's Avatar
DeBaGo
Default 1991 Fuel Pump Relay
Car has spark, will start on starter fluid, pump isnt priming at all.
Going to replace relay 1st. I cant find it! Another member sent me a pic, put I dont have anything like that under my hood!
I took some pics of the area where the relay was in the pic I was sent. I also took a pic of the relay they said was for my car.
PLEASE HELP ME!! I havent been able to drive the vette for a week now!!
edit...click on the pic of the car to see the album
Old Feb 2, 2007 | 01:36 AM
RRT vette's Avatar
RRT vette
I not positive, but I don't think the FP relay is in the same location on the 90-91 as it is on the 84-89. I think I have read before that the relay is under the passenger side dash. Perhaps someone can verify or disconfirm that. The pic I sent was from my 86 which is by the windshield wiper motor.
If you have tried to start the engine, as long as the oil pressure switch is good and you can achieve ~4 psi oil pressure while cranking....the fuel pump should run. Again not sure about the 91, but on my 86, you can use a jumper wire from the positive side of the battery to terminal G of the ALDL (all the way to the left bottom terminal) and it will run the fuel pump continiously until the wire is removed. You can remove the gas lid and rubber boot and test the fuel pump connector above the tank with a test light or voltmeter to see of you are getting signal.
Also, if you are quick and without the jumper wire, you can use a test light on the fuel pump fuse. Turn the key "on" and within 2 seconds touch the fuse with the test light to ground. If the relay is good the test light will light up and then go out....within 2 seconds.
Last test is to remove the fuel pump and supply a direct 12v source and a ground to the pump. If it is good, you will hear it.
Check the fuel pump fuse also. By spraying starter fluid in the intake while cranking and the engine starts....this pretty much tells you that you have a fuel problem. A fuel pressure gauge is handy in this situation.
Old Feb 2, 2007 | 01:40 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
That was on the pre-90 cars, doesn't apply to your 91.
I pulled up the parts book, shows the relay sticking forwards out of the harness, part number 14100455 should be on it. Looks like it could be up front, maybe near the throttle body.
Old Feb 2, 2007 | 07:41 AM
DeBaGo's Avatar
DeBaGo
Just to be safe I pulled the panel under the glove box and it isnt there. Central coaster, I dont know of any wiring like that near the throttle body. I stood out in the pouring rain trying to fix this, surely someone has a pic or can give me the exact location.
Thank you.
Devon
Old Feb 2, 2007 | 08:45 AM
rodj's Avatar
rodj
Should be same as '90.
Under dash , group of 3 square Bosch relays in a common holder.
Have loom out of car but relays are approx 1 foot to left of fuse box.
At the same location, several other looms exit main loom including wiring to RH door , passkey box and another 2 seperate similar relays
Old Feb 2, 2007 | 08:47 AM
mseven's Avatar
mseven
Originally Posted by DeBaGo
I cant find it! I dont have anything like that under my hood!
It's not under the hood, it is located under the passenger side kick panel inside the car. When you remove the carpeted peice, there will be a strip with 5 relays running horizontal to the firewall, the fuel pump relay is the one in the middle.
Old Feb 2, 2007 | 09:30 AM
DeBaGo's Avatar
DeBaGo
Found the group under the glove box. There is a set of three then a set of two. I replaced the middle one in the set of three. Still hear nothing from the pump and nothing comes out of the schrader valve.
Old Feb 2, 2007 | 01:08 PM
Hooked on Vettes's Avatar
Hooked on Vettes
I believe the fuel pump relay for L98 is under the dash behind the right hand side of the instrument panel.
The fuel pump #1 relay under the passenger side dash is only used if you have a ZR1.
Old Feb 2, 2007 | 01:12 PM
RRT vette's Avatar
RRT vette
The relay is probably good...and you fuel pump is dead. Try the tests above.
Old Feb 2, 2007 | 02:22 PM
DeBaGo's Avatar
DeBaGo
My only concern is, I've never had a pump just "go bad". there were always signs leading to it. Oh well. I will see how it goes when I get home tonight.
Old Feb 2, 2007 | 03:07 PM
CentralCoaster
This test still powers the pump through the closed contacts of the fuel pump relay. So if the relay connector is bad or shorted, or the relay is destroyed internally, this might not work.
Old Feb 2, 2007 | 10:13 PM
RRT vette's Avatar
RRT vette
Might not...that's why I listed a few ways to test the fuel pump and circuitry.
Old Feb 2, 2007 | 10:54 PM
mjones's Avatar
mjones
Well I'll jump in.... My 91, the fuel pump just quit on me this Wed. A.M. with no warning signs what so ever. Fired right up, drove it about 2 miles, stopped for 5 mins. Got back in put the key in turn and no noise from the fuel pump before the engine turned over. It started a few times, but coffed and sputtered like it had run outta gas. It's now in the shop and it's definitly the fuel pump and they might have to replace a sending unit as well from what they're saying.
Old Feb 3, 2007 | 11:37 AM
DeBaGo's Avatar
DeBaGo
I tried all the relays. They appear to be ok. I bought a new pump today. I cant get the rear cover off the tank though. Looks like the screws are stripped. Oh, well. Off to a shop to get screwed over I guess.
Old Feb 3, 2007 | 12:07 PM
RRT vette's Avatar
RRT vette
There are 4 philips head screws that hold the gas lid assembly down. Try and pull up on the lid as you unscrew them. Once that is off you need to take the gas cap off to get the rubber boot out. Make sure to clean everything good before taking the cap off and again before taking the pump out, if so.
First try and apply 12v and check the ground on the assembly. You can test the fuel pump while in the tank as long as the connections at the pump are good. If it does nothing, then remove the nine bolts. Each one should have a o-ring around it...inspect and replace if needed. If the rubber gasket seal looks bad replace it too.
Old Feb 3, 2007 | 05:07 PM
DeBaGo's Avatar
DeBaGo
Woo Hoo!! Just went ahead and replaced the pump. Car runs like a champ!!!!
Thanks to everyone!
Old Feb 3, 2007 | 05:10 PM
RRT vette's Avatar
RRT vette
Old Feb 3, 2007 | 05:33 PM
DeBaGo's Avatar
DeBaGo
By the way I did go ahead and order the full 3 volume fsm from Helm as well!
To 1991 Fuel Pump Relay
