93 Auto transmission problem
Old Feb 2, 2007 | 12:21 PM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default 93 Auto transmission problem
Ok, here's what I've got. 93, auto, 159K miles, tranny was rebuild with 100K on it I believe.
Loud whining noise in P and N. Shifts funny (slow/underpowered feeling) when starting from 0 mph. I think in 2nd, it runs the RPMs up kinda high under light throttle (3k rpms) from either 2 to 3 or 3 to 4 it shifts quite hard making a grinding noise. It seems to run fine in 4th.
Anyone have any suggestions??
Old Feb 2, 2007 | 12:59 PM
BerniesVette's Avatar
BerniesVette
Swap it for a 5 speed!
Bernie
Old Feb 2, 2007 | 01:10 PM
vetteweiser
Cruise-In V Veteran
Bernie
I'd prefer a six-speed
newest update: Went to move the vette so I could take my truck and....
NO REVERSE!!! R engages but feels like I'm power braking it and does not move an inch. I dont want to apply too much gas as I'm sure that would really mess something up
Old Feb 2, 2007 | 01:18 PM
Pete K's Avatar
Pete K
You likely broke the rear planetary or the lo roller clutch. It should become very clear when it comes apart. Do not drive it. The more you try, the more you will tear up. Hardparts are expensive and you want to minimize damage.
Old Feb 2, 2007 | 01:19 PM
BerniesVette
I have to apologize, I visit the C3 forum and thought I was there. You are right, the 6 speed would be the best. It sounds like you have some serious issues with your auto. If you are wanting to stay auto you might want to have it towed to a reputable shop and have it removed. I don't believe I would try to drive it anywhere.
There have been some 6 speed swaps threads lately if you want to spend the bucks.
Bernie
Old Feb 2, 2007 | 01:27 PM
vetteweiser
Cruise-In V Veteran
Pete,
Would there be any harm putting it in N and pushing it out of my driveway so I can get to my truck? Driving is over for it right now
Bernie,
Do you have any links w/ pricing for the 6 speed swap?
Old Feb 2, 2007 | 01:39 PM
Pete K's Avatar
Pete K
Neutral is fine. Good luck.
Old Feb 2, 2007 | 01:45 PM
vetteweiser
Cruise-In V Veteran
Thanks Pete
Old Feb 2, 2007 | 03:23 PM
BerniesVette
Keisler is located here in the Knoxville area and are a supporting vendor. I saw a thread on a ZF6 swap that Central Coaster did and someone else. I will look for it for you; in fact, I'm gathering information on it right now myself. I did a T5 5 speed swap in my 79 last year from an auto and it made a tremendous difference!
Bernie
Old Feb 2, 2007 | 03:29 PM
BerniesVette
Vetteweiser,
I just refreshed the thread on "How to swap auto trans for ZF6". Check it out. It has some good info.
Bernie
Old Feb 2, 2007 | 06:01 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Gene, I have a fresh 700R4 out of my 93 if you want. I will make you a deal and even meet you in Tampa with it
Old Feb 4, 2007 | 07:28 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Gene,
I dont think the swap to a ZF6 would be a good option for you, but it wouldnt be much different that the swap I did on Michelles car, the only difference would be adding the pedals and mounting the hydraulics......and a lot of time.....
off the top of my head I would guess youd be looking at around 4k in parts if you found some deals......
To 93 Auto transmission problem
