Engine fan will not stop running
http://misterbill.homeip.net/vette/w...ooling_fan.jpg
If the fan that won't shut off is the one you see when you open the hood, that one is run by the computer.
If the fan that runs is the one you can't see but you can hear, it's the aux fan.
1. first the aux fan..........
since the fan shut off after you parked it after an hour, open the hood, charge the battery, start it up.
The fan comes on, pull the wire off the sensor in the left head in between the cylinder #1 AND #3.
If the fan stops, it's the sensor in the head, if it keeps running, it's the relay.
2. Main fan.....
If the main fan that you can see comes on, there is a relay on the left inside wheel well, just lean in, and look down past the master cylinder, and there is the relay.
unplug the relay, and the fan will stop.
then use Mr. Bill's checkout procedure to check out the relay.
The relay will have little letters on the relay indicating a,b,c,d,e.
use an ohm meter and 2 paper clips. remove the relay, prop it up so you can see the connector.
take the meter leads and clip them onto the paper clips straightened out, touch the leads to pin A and C. there should be continuity. If there's no continuity, touch the leads to E and A. If there's continuity, the relay is stuck in the on position.
touch the leads to pins D and F, and you should read the relay pull in coil resistance.
Chris
