Remove frisbee
Old Feb 3, 2007 | 01:48 AM
Crazy Kev's Avatar
Crazy Kev
3rd Gear
Default Remove frisbee
Where can I find info on removing the frisbee on my 1986 vert? Large change in performance?
Old Feb 3, 2007 | 03:59 AM
rodj's Avatar
rodj
Undo bolts attaching it to water pump and keep for 50 years as collectors item.
May have to put a washer on each bolt as spacer if bolts too long.
Doubt you will see any SOTP improvement but anything that removes unwanted mass from the engine rotating assembly is generaly considered good.
Old Feb 5, 2007 | 12:56 PM
l1sikes's Avatar
l1sikes
Greatest benefit is the improved maintenance access, especially when installing new accessory drive belt.
Old Feb 5, 2007 | 01:00 PM
KeyWestJack's Avatar
KeyWestJack
What purpose was its intended purpose?
Old Feb 5, 2007 | 01:11 PM
vader86's Avatar
vader86
86 does not have a frisbee, only 88+
Old Feb 5, 2007 | 01:33 PM
silver86's Avatar
silver86
Ahh....kept wondering what everyone was talking about.
Old Feb 5, 2007 | 01:45 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It's amazing how heavy it is!
Old Feb 5, 2007 | 01:59 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Supposidly it's there to dampen vibration from the air compressor via the serpintine belt. It makes a terrible frisbee! (I've tried)
Old Feb 5, 2007 | 02:18 PM
rdefonce's Avatar
rdefonce
Removing the "frisbee" won't un-balance anything, right?
No bad things ever happened from removing it?
(other than what was mentioned in the thread about possible vibration from air compressor.)
Old Feb 5, 2007 | 02:29 PM
Crazy Kev's Avatar
Crazy Kev
3rd Gear
Default Thanks
Thanks for the response
Old Feb 5, 2007 | 03:12 PM
vader86's Avatar
vader86
I've never heard of anyone having a problem after removing the frisbee.
Old Feb 5, 2007 | 03:24 PM
zr1fred's Avatar
zr1fred
Old Feb 5, 2007 | 05:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yep, that's the word I got from Gordon Killebrew when I asked about the frisbee in 2001 at Carlisle.
Old Feb 5, 2007 | 06:41 PM
KeyWestJack
He be da man to know.
Old Feb 5, 2007 | 06:45 PM
Grenkepr's Avatar
Grenkepr
Removed mine and all was ok until I turned on my ac. Severe vibrations when I hit 2200 rpm. Put it back on and all was ok. I have heard that it affects some cars and not others. Guess I was one of the unlucky ones.
Old Feb 5, 2007 | 08:19 PM
Kool88vette's Avatar
Kool88vette
I took my frisbee off, no problems.
Old Feb 5, 2007 | 10:29 PM
65Z01's Avatar
65Z01
Had you checked the related A/C Compressor mounting brackets and the tensioner?? Did you check condition of the serp?
Gordon did tell me that an engineer once found A/C Compressor vibration after they went to the new style compressor in '88; so the installed the frisbee to dampen the belt acceleration.
Old Feb 5, 2007 | 10:35 PM
pablocruise's Avatar
pablocruise
Mine became the anti-theft device for the bathroom key at the shop
no one has "lost" the key yet
Old Feb 6, 2007 | 12:15 PM
rdefonce's Avatar
rdefonce
HA HA HA, LOL.:-)))
Great use for it.
Hope no vibrations after it's removed . . .
To Remove frisbee
