Just curious I have a LT4 in my 64 Corvette GS, hot cam, custom side exit headers into 3 1/2" side pipes with a maxium flowing 2 1/2" flow through inserts, pcm for less OBE 1 programed computer. Any ideas what I might be looking at in HP? Its running but not on the road yet.
Any thoughts about what kind of gains I might see getting the heads ported or changing to AFR's? Thanks
Assuming it's stock displacement, I think it would be safe to say that you are over 400hp at the crank. With head porting or a good set of AFR's...425hp maybe.
Sounds sweet
LT4, stock bottom end, compcams 503, ported heads, EM headers, high flow cats, electric water pump. ATI damper, 58mm throttle body, & a few other tricks...
Those might be some of the best stock bottom end #s ive seen. Youll have to race Jonecap down the track to see if your cars up to par in the 1/4 mile. I think you should be in 11 sec territory with that kinda hp.
The car is, but not so sure about the driver.....
This was on street tires, fast lapped (motor too hot)---which I did because they had just treated the track........previous runs I had serious traction issures, so launch is from idle..
Hey. He's closer to you than me
Nice in car video, BTW. Drag radials and you'd be at least low 12's for sure .
