1996 courtesy lights still on
Old Oct 4, 2001 | 10:39 PM
paul 86cpe's Avatar
paul 86cpe
Cruising
Default 1996 courtesy lights still on
help, i checked all of the suggestions that i received before and still can't
figure it out. my courtesy lights stay on for 15 min.(my last post i said that
they wouldn't shut off at all, but after working on it for a while i discovered
if you have the patience to stand and wait they will shut off) I have checked
door switches,relays,hatch switch, door lock switches, etc. any suggestions ?
thanks, Paul
Old Oct 4, 2001 | 10:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 1996 courtesy lights still on (paul 86cpe)
Try manually pushing each switch in turn to see if they will turn off in like 30sec. A switch could be borderline.
Old Oct 4, 2001 | 11:09 PM
traxx1's Avatar
traxx1
Look under your dash, above the passenger knees under the dash is the timer for your courtesy lights, it is white plastic and you can tell it by unplugging it and all courtesy lights will go off, replaced mine (mine wouldn't shut off) and everything is ok now,cost about $20
:jester :jester :jester
Old Oct 5, 2001 | 12:22 AM
Rich_01659's Avatar
Rich_01659
Default Re: 1996 courtesy lights still on (traxx1)
you have a bad switch ...... the ECM will time out in 15 to save the battery. the hatch switch is good because the time out dose not work for open hatch.
To 1996 courtesy lights still on
